Question about Nokia Consumer Headset
Switch service i have a nokia6085h imei is354831/01/840/190/1 im in the us the phone is at&t i want to switch it to cincinnati bell thank you
  • 906 Answers
Good day,
hope this link below will answer your query.
nokia
Posted on Jul 28, 2010
6ya staff
SOURCE:
I need an unlock code for nokia 6086 locked to cincinnati bell imei:354811010096438
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 03, 2012 | Nokia 6086 Cell Phone
Need puk code cincinnati bell i wireless motrola
Instructions
    • Contact Cincinnati Bell Wireless customer service from another phone by dialing 1-888-391-3925. Ask to speak with a customer-service representative.
    • 2 Inform the representative you need to switch service providers and need the correct code to unlock your phone from the network. You do not need to specify a reason. Keep in mind that Cincinnati Bell does not have to release the code, but generally, if you are moving to another location not covered by Cincinnati Bell, the company will release the code.
    • 3 Give the representative the make and model of your phone, along with the IMEI (International Mobile Equipment Identity) number. You can obtain your IMEI number by pressing #06#. The representative will retrieve and divulge the unlock code.
    • 4 Put the SIM card from your new provider into your phone and turn it on. The screen will automatically ask for the unlock code. Input the code to unlock it, and your can begin using the phone.
Courtesy: How to Unlock a Cincinnati Bell Wireless Phone ' eHow.com http://www.ehow.com/how_7652326_unlock-cincinnati-bell-wireless-phone.html#ixzz1jmmG9z4v
Jan 18, 2012 | Motorola Lands Phones
When i turn my phone on it says input NP code, I have went to the store I bought it from they have never heard of such code I called cincinnati bell they said call motorola i called motorola they said call...
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jun 01, 2011 | Cell Phones
How do i unlock a cincinnati bell phone? is a nokia 5800 xpress music... thank u!
You can get the Master Reset Code from service provider and Reset it....
Feb 13, 2011 | Nokia 5800 XpressMusic Smartphone
I have a motorolla razr v3 through at&t and i wanna have it unlocked to cincinnati bell how can i do that
Call ATT and ask them what the Unlock code is - and if you have an account with ATT than they will help you - if not - than They might not.
Or Call Cincinnati Bell to see if you even need to unlock it.
hope this helps
thanks
Mar 31, 2010 | Motorola Mobility RAZR V3
I need the subsidy unlock coke for a nokia 7610 locked through Cincinnati Bell my IMEI # is 356405020768546
Mr,give me my personal license key IMEI 355700004490922
pleas...help me ser...:)
Jul 14, 2009 | Nokia 7610
Roaming doesnt work
Try typing *228, and send. Select option 2 -- updating your roaming capibilities. The phone will go through a sequence of unlocking and reprogramming...DO NOT SHUT THE PHONE OFF DURING THIS PROCESS. It only takes a couple of minutes...or less...and will notify you that the phone was successfully updated. I had a similar problem a couple of years ago, and this seemed to solve it. Good luck!!
Jun 10, 2009 | Motorola Mobility RAZR V3m Cellular Phone
I have a nokia 3120 IMEI: 356245001924712 need an unlock code
These Nokia Unlock Codes are Generated For Nokia 3120 with IMEI: 356245001924712 (DCT 4) Locked to Provider Cincinnati Bell Wireless in U.S.A. and will only work with this phone!
#pw+116134435443545+1#
#pw+244865560200176+2#
#pw+848451762636161+3#
#pw+906812726400622+4#
#pw+783200705164011+5#
#pw+322106646023513+6#
#pw+035013454322224+7#
Recommended CODE :#pw+035013454322224 +7#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 035013454322224
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 7
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked remotely
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+116134435443545+1#) if code that does not unlock your phone STOP!
Mar 30, 2009 | Cell Phones
Nokia unlock code
take it to its service center and ask them that i have set a password and forgot it they will unlock it but do not tell them the truth
May 16, 2008 | Nokia 6600
Nokia unlock code
go this link they will open for you
www.unlockinglab.com
Mar 02, 2008 | Nokia Consumer Headset
Nokia Consumer Headset Logo
Top Nokia Radio Communications Experts
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Ekse
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
