Expert
- Posted on Mar 28, 2010
Re: When the oven is on the trip switch fuse goes off. ...
Thanks Louise for clarifying hob for me...:). Yes, I believe it's worth replacing the element. They can check out the element for you by using an ohm meter to see if it's bad. If so, then I'd replace it. If not, you can write me back and I'll help you figure it out.
Good Luck! Jim
the hob is the cooker plate where you put saucepans andfrying pans. In this case the hob is fitted separately from the oven.
Thanks for your reply.
The hob is the plate where saucepans and frying pans go for boiling and frying. In this case it is separate to the oven though the same make. Thank you for your reply.
I'm sorry, but what is "hob"? If it is the element, sure it's worth repairing. Help me with the "hob", then I can help you. Thanks!
