Need help with my printer
I'm trying to print out some pictures on my epson dx3850, but the prints are coming out with lines through them. i was told that i might need to clean my lens. is that the problem? if so, how do i do that?
    Sergeant:
  • 349 Answers
It is most likely you need to clean the printer head,
then align the printer head,you should find the option to do this in the printer software.
you may need to do this a few times ,if this fails to correct the problem you need to replace the ink cartridge.
please rate my suggestion
good luck
Terry
Posted on Mar 14, 2008
SOURCE:
Will print a printed page with picture fine, try to print photo or any picture comes out with lines across
print heads need cleaning. check the tools/options maintenance for the print head cleaning option. It should be able to do a "self clean"
Mar 22, 2015 | Epson WorkForce 630 All-in-One Printer...
Epson stylus dx3850 ink saying empy when full and wont print
Hi
Try turning the printer off and disconnecting it from power completely.
Check for paper jams on the machine.
Clear any print queues.
Mar 02, 2012 | Epson Office Equipment & Supplies
WHAT CAN I DO TO HAVE BACK MY PRINTER PROGRAMMED TO MY COMPUTER
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Feb 21, 2011 | Epson Stylus Color 400 InkJet Printer
My Epson R320 prints blue lines across and over all my printing including DVD printing is the anyone out there that can help it loohs just like a writing pad that contains lines peter
Epson told me it needed to be serviced but I did not accept that. It was hardly used. But everything I tried failed at first. Cleaning the print head barely showed any inprovement. Finally I just removed all the ink cartridges, then just put them back in. Something reset is my guess. Cleaned again and now it is printing without any lines. As good as new so far...
Nov 17, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Have used compatible ink before on my dx3850 epson. have some more cartridges and it wont print anything
the head in which the cartridges r inserted is now blocked due to ink dried up in the holes from where the ink comes out.a common epson printer problem.now the whole head needs to be replaced.they r avaiable in the maket just get 1 from your neares epson servi center.or nearest epson printer dealer.
Nov 29, 2008 | Office Equipment & Supplies
Printing blue picture with yellow lines
I had this problem too.
There was no low ink warning but one colour was missing, as seems to be your case.
Either the jet is still blocked or the colour is dry.
I had to change the cartridge and all worked fine.
Jul 07, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
Oct 16, 2007 | Epson Stylus 1400 InkJet Photo Printer
Open Questions:
AVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USAAVG #[+1888//499//5520;-]tech save customer.team AVG number USA
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
81 people viewed this question
Ekse
Alun Cox
