Watching a dvd on my magnavox TV
I have hooked up the cables from my TV to my Dvd player, but can't get the picture on the TV.
  • for_1_qt Nov 08, 2008
    I have lost the remote control to my television. I have hooked up the dvd player but it will not work. Is there a way I can use my DVD player on this television?
  • 44 Answers
Hi: If you used the av jacks on the back of the set, you must switch the TV to video mode. Is the DVD new or used?
Al
Posted on Mar 13, 2008
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I hooked my player up to my RCA tv, but it will not show a picture when I record a TV program. I have cable. What am I doing Wrong
You might have an INPUT going to an INPUT, or vice versa. Always make sure that an INPUT goes to an OUTPUT and an OUTPUT goes to an INPUT. If this is not the problem, then you have a faulty cable somewhere, test it and if faulty, replace it. Good luck to you!
Nov 27, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I get from cable TV to DVD player
All you should have to do is press the dvd button on your remote to go to the dvd player. Then press the vcr button to go back to the cable tv, if it is hooked up the same way as mine. And you can tell if it is by putting in a vhf tape and you can start watching it play. Otherwise you will need to press the input button on your tv remote until you see the vcr or dvd main screen. from there press the dvd button on your remote for the dvd player or the vcr button for your vhf. After you are done with watching your movies and wish to go back to the cable or tv programs use the tv remote and press input until the shows come back on
Aug 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
No picture or sound magnavox mwd200g dvd player
on the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
For tv/dvd /vcr question answers.
http://www.dvddemystified.com/dvdfaq.html#1.27
Mar 02, 2009 | Philips Magnavox MWD200G DVD Player
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
