Canon PIXMA iP90 Mobile Printer
Problem for Canon PIXMA iP90 Mobile Printer
Waste Ink Absorber full - Canon Pixma
By durfmcgoon on Mar 13, 2008
My error message is saying "waste ink absorber full". What do I do?
Same Problem
Dec 05, 2008
-   waste ink is full pixma mp 130 help -   peterwilson1
Nov 11, 2008
-   yes, with the canon i90-   Guest
Aug 31, 2008
-   Canon Multipass MP 390 -- sending signal that the waste ink is almost full-   Guest
Jul 17, 2008
-   waste in absorber full pops up when trying to print. Can you help?
After cleaning heads 3-4 times and cleaning bottom plate printer is printing black again but halfway down page the object has blank horizontal lines like the rollers are dirty. -   Guest
Mar 21, 2008
-   I have a Canon Pixma ip4000 that is giving me this error message. I'm sure I can fix it myself if given proper directions. When my print head needed replacing and I phoned Tech Support, they told me to just get a new printer! The told me NOT to touch the print head! Well...it wasn't printing worth a hoot anyway so I pulled the print head, cleaned it with cotton swabs and water, and gave it some good "shakes" over the sink. It's been printing since May 2006 with the same print head. So much for Tech Support. So...any help for me?-   Faerymagikal
Best Solution
posted on Mar 13, 2008
Very Helpful)
ginko
Rank: Guru  Canon Computer Hardware  Expert
Rating: 89%, 5217 votes
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #2
posted on Jun 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
iP4000 Serivce Manual link
http://rapidshare.com/files/120417696/iP4000_Service_Manual.pdf
Solution #3
posted on Apr 24, 2009
Not Rated)
alicehuntdav
Rank: Apprentice
Rating: 0%, 0 votes
waste ink absorber is full how do I solve this problem
Was this helpful?
Yes
No
Solution #4
posted on Dec 05, 2008
Not Rated)
peterwilson1
Rank: Apprentice
Rating: 0%, 0 votes
my pixma mp 130 is waste ink full ...how do i reset the printer please i not in aposition to replace this printer....peter
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP90 Mobile
Questions and Unsolved Problems for Canon PIXMA iP90 Mobile
Do you recommend Canon PIXMA iP90 Mobile Printer?
Answer
Answer
my cannon prints ok in black but not in colour. The colour which comes out is wishy washy and... (More)
Answer
when i print, my printer dialog box on my computer says that the printer is downloading... (More)
Answer
My cannon pixma 90 prints color but no black, suggestions?
Answer
Colour prints have a vertical red line near a green one (not right next to each other), always in... (More)
Answer
Paper does not feed, when it does, sometimes draws it unevenly
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
