Question about Vizio P2 42 in. HD-Ready Plasma Television
Picture shifts to left
Recently I have noticed that the picture on my vizio occasionally gets "pushed" to the left. It leaves a black stripe on the right side of the screen about 2-3 inches wide. It would be comparable to going to the movies and the projector not being lined up with the screen, except of course the picture doesn't run onto the wall to the left of the tv, it just dissappears. Especially noticeable when there is any type of words on the screen, such as during the news. Any ideas??
  • 1 more comment
  • AlpineX Mar 28, 2008
    I am using a HDMI cable connected to a HD cable box.
    I don't think it is a result of a button accidently getting pushed. It can be fine one minute and the next the entire picture is moved over. Happens so fast that I have yet to notice it actually happen, but whenever I do notice it there hasn't been anyting moving near the tv or the remotes. The only temporary solution I have found is turning the tv off for a few seconds and when I turn it back on the picture has gone back to normal - this works 99% of the time.
  • spicyali213 Feb 19, 2009
    For anyone who just bought the new Vizio 32" 1080p, 120Hz TV, have a Time Warner Cable HDTV box, using the HDMI cable and having problems with your aspect ratio (black bars left and right on the screen) then go to:
    1. Settings
    2. Display
    3. Output resolution
    4. Click on all of the resolutions : 480i, 480p, 720p, 1080i
    6. Set Aspect Ratio 16:9
    6. Problem solved
    You can go back and forth between regular channels and HD channels without a problem and don't have to worry about resetting the aspect ration every time you turn off your TV...hope this helps!
  • Robert Johnson May 11, 2010
    are you using HDMI, or HDMI switch box?
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Posted on Jun 12, 2010
  • 4 Answers
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Posted on Oct 03, 2008
I have a Vizio 42" LCD tv, with and explorer 8300 DVR box. I have tried the different suggestions regarding choosing this or that resolution from the settings menu on the DVR box. None have worked for me, but this is what does work:
The problem only occurs when switching from 1080i or 720p to 480i. When I get the black stripe on the right side when changing to 480i, I change to a 480p channel, e.g. music choice channels, I then press the last/previous which takes me back to the 480i and the screen is perfectly aligned.
I contacted Vizio about this glitch and they told me it was a Cablevision firmware issue, I doubt it is. As I do not have this issue on my Samsung LCD.
Posted on Jun 14, 2009
    Sergeant:
  • 395 Answers
When this happens leave the tv on, shut the cable box off from the front of the box then hit menu on the box. the customer setting menu will appear use the curser buttons on the front to select HDMI setting. it will say color output 4:4:4 this is not a ture standard set it for RGB and hit menu to escape.
Posted on Mar 28, 2008
  • 25 Answers
Sounds like the horizontal alignment is the issue. First make sure that there are no buttons being accidentaly pushed or stuck in a pushed position. Next try putting the remote in a secure place where you can monitor it. Inspect the area around the tv where the horizontal adjust button is. I have seen things like blinds, pets rubbing, even a plant that had pushed a button on a tv. If you conduct this little science project and do not get and results take the tv to an authorized repair center and they will help you.
Posted on Mar 26, 2008
4 Suggested Answers
  • 142 Answers
SOURCE: Vizio L37 37" LCD screen screen is cracked.
I agree your screen is cracked. It's smooth to the touch because you're not actually touching the LCD section of the screen, just the protective coating. The advantage of owning an LCD TV over plasma... you can replace the screen either by going to the manufacturer or some place like e-bay. It's not a difficult thing to do if you take your time and pay attention to the details.
Good Luck
Posted on Apr 09, 2008
Highdefjeff
  • 124 Answers
SOURCE: Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Posted on Apr 24, 2008
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV picture not available.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 21, 2010 | Vizio L37 Television
Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Jan 04, 2010 | Televison & Video
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Vizio Plazma 42in hdtv has a 2inch red verticle stripe on the left side and now the right side of the screen. It is a 4 year old 2400 dollar set I go at Costco.
Hello
This is most likely being caused by capacitors in the power supply changing value. Take it to a reputable repair person.
Good luck
Sep 23, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Speedometer just stopped working with no notice
If trans is still shifting its most likely a blown cluster fuse or bad cluster.If you have a check engine light & trans don't shift most likely blown trans fuse or trans vss (speedo) harness at right drive axle broken puple with white stripe wire or light green wire with black stripe
Sep 02, 2009 | 2005 Pontiac Sunfire
Need wireing diagram for DEH-1600
  • Gray - Front Right +
  • Gray w/Black Stripe - Front Right -
  • White - Front Left +
  • White w/Black Stripe - Front Left -
  • Purple - Rear Right +
  • Purple w/Black Stripe - Rear Right -
  • Green - Rear Left +
  • Green w/Black Stripe - Rear Left -
  • Blue w/White Stripe - System Remote Control (Ant)
  • Black - Ground
  • Red - Switched Power
  • Yellow - Always On Power
The Pioneer DEH-16 is the same as the 1600. The only difference is the faceplate and LEDs. It can be found at the Pioneer website.
Jun 03, 2009 | Pioneer DEH-1600 CD Player
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
1,697 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
