Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
819
Jghjghjhhgjhg
Jghjghjhhgjhg
My HP 6110 scanner,photocapier, printer, fax machine is showing remove and check cartridge,which I have done.
I have also changed the cartridges for new ones,but still the same message and problem
It wont scan either, it seems that this fault is jamming the whole machine up!
Any suggestions, Please Terry
I BOUGHT A HP ALL IN ONE 6110 AND BEED A DISK TO INSTALL WHAT CAN I DO TO FIX THE PROBLEM I DONT HAVE THE DISK GOT IT FROM A YARD SALE HELP
SOURCE: when someone is trying to send a fax to me it just
The auto answer function is not turned on. Here's how to do it ! Note the right arrow looks like >
NOTE:
The default Rings to Answer setting is 5 rings.
How do I retreive faxes? A fax came thru today, but its was not on auto answer.
my hp rings but still no fax come in
I have everything else working the scanner printer but are you supposed to use the area code to send or recieve fax and what about putting a number 1 in front of area code & number
PLEASE RESPOND ASAP
THANK YOU
My HP 6110 cannot send or receive faxes. It is supposed to change tones when connecting and receiving but it does not.
I just Hear the ring of the fax and it's appear (coneccting) and then (receiving) then suddenley the transmision is faild .
Today it is error code 283. Sometimes it can be another code. Rings but won`t receive fax
