I want to setup a network using a cable modem ,linksys router, hub/switch and another linksys router at a remote section of the house to provide wireless capability. I ran an ethernet cable from the main router to the remote location, but I'm confused on the hard wiring of the components. The hub is a 4 port stackable ethernet hub with 2 switches 1 labeled stack ID in #1 position the other switch is labeled node and uplink, currently in the node position.
  • mcmm9ss Mar 21, 2008
    Hi Pat, thank You for the info. I'm printing it out and it seems like alot of pertinent info, step by step. In a easy to understand format.
  • 27 Answers
If you are using Windows Vista, you can follow the instructions from the link below.
If it's XP, you can follow the instructions from the link below:
Hope this helps!
Posted on Mar 17, 2008
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Since changing isp to comcast my ew5hub will only allow one pc at a time and isn't dependent on which port used. it was working fine while using at&t u-verse. any ideas?
The only thing I can think of is that AT&T was providing you with a modem/router and your new ISP is only giving you a Modem if so you will need to buy a Router to put in between your modem and your Hub.
That said a router has an integrated switch so you might not need your hub anymore.
Oct 29, 2010 | Linksys Instant Networking Hub
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
I can connected to my linksys, but the the linksys
there is nothing issue with the linksys ist chk the ipaddress which u had provided to the modem and router is in same serious for eg: if ur modem is in ten provide ur router ip as and also chk whether the connection type is in PPPoE and also chk whether u r able to browse through modem which is provided by the ISP....
Feb 18, 2010 | Linksys Cable Modem
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. may be able to provide additional support if you can give us more details about your installation.
Jul 20, 2009 | Computers & Internet
High ping
Question, why are you using so many different routers? Sounds like you are causing a bottleneck in the network.
This is how I have my network.
Modem ---- PFSENSE Firewall (currently my DHCP Server) ------- Cisco Switch ------ Patch Panel ------- out to my Servers, computers and one wireless router. See only one machine is managing my IP addresses.
Buy a patch panel and run wireing to all the locations in the house or just run wireless.
Mar 31, 2009 | Linksys BEFW11S4 802.11b Wireless...
Wired Router problem
Are you working with a router or a hub...there's a big difference in how they work. The heading above your post says LinkSys NH1005 Networking hub, but your post refers to a Router.(?) Can you provide the exact brand and model number from the device?
A router can support several devices and allow them to share a single IP address on the Internet. Router setup is usually automatic, but there are several settings that can be adjusted manually if it doesn't work right. If this is a hub, the ability to assign addresses to more than one device at a time will have to be set up by your ISP on the cable modem.
Your description of the problem sounds like you may be working with a hub, and the cable modem isn't supporting connection of more than one device at a time to the Internet. If that is the case, you will need to contact your cable provider to see if they can support more than one network device using a hub. If not, you will need to upgrade to a router.
Jan 22, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
David Payne
David Payne
