Question about KitchenAid KEMC378KSS Electric Double Oven
How do i change light bulb for my oven
Please can you tell me how to remove the light bulb from my arrow oven so i can replace it.
  • 1 more comment
  • g10man May 25, 2008
    How do you replace the bulb in the microwave unit? Is there a service manual out there?.
    Thanks.
  • John Nov 08, 2008
    I also need toreplace a light bulb in the microwave model KEMC308KSS. The manual does not show how or what type of bulb is needed
  • cleetri Nov 21, 2008
    I have the same problem...
    I can tell the bulb in the microwave unit is spring loaded and will twist but i cannot get the bulb cover to release. I did find out the the part number is '8186287'. I also was told that the bulb costs $51.95.
    anybody have a solution??
    New Friend:
Here is a simpler method from the same website mentioned in solution #1:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Posted on Feb 18, 2011
To replace the bulb on kitchenAid microwave:
You'll have to pull the oven unit out of the wall:
Shut off the power first - make sure you get both ovens!
1. Open the lower oven door.
2. Remove the two screws holding the side trim in place, down low.
3. Pull the side trim pieces off to expose the screws holding the oven in the cabinet. Remove those.
At this point you're going to want some help, or get creative. You need to pull the oven unit out from the cabinet, and it's heavy. I rolled an automotive floor jack under mine with a piece of plywood, slid the oven out most of the way, then lifted the jack until it took most of the weight. I then pulled the oven out until just the back edge was resting on the cabinet edge. [A chair may work just as well.]
4. Take a minute to study the top of the microwave and start locating the screws holding the top sheet metal panels down. You may also want to loosen the conduit clip and some other things to make it a little easier.
5. Remove the screws at the sides of the control panel.
6. Remove the screws holding down the top cover.
7. Remove the top cover, and the control panel (unplug all of the wiring harnesses.)
8. Remove the horizontal screws around the sides near the top that are holding down the next layer of metal. There are two in the back, you'll have to get behind the oven. I rotated mine in place just enough.
9. Remove the two vertical screws at the front corners.
10. At this point you should be able to lift up the panels in the front just enough to get to the light bulb.
I found this solution at http://www.howtomendit.com/answers.php?id=51232 and it seems correct based on a conversation I had with a repair person at MMAB Appliances. Hope it helps.
Posted on Dec 23, 2008
SOURCE:
Can you tell me the light bulb type/size and how to change it please?
Refer your question to a local appliance parts supplier or an Evolution dealer/supplier.
Jun 07, 2016 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
My E30EW85GPSS double wall oven lights won't turn on. Both ovens heat up but neither oven lights up. Help!
Oven lights burn out just like any other light bulb. If you remove one, you may be able to tell if it's burned out if it is rattling or discolored. They are generally an inexpensive bulb to replace.
Sep 24, 2013 | Electrolux Icon E30EW85GPS 30" Double Wall...
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Whirlpool Super Capacity 465 oven can't figure out how to change the lightbulb and it is not listed in the owners manual. Can anyone tell me how to remove the lightbulb cover?
The glass lens cover for the bulb is usually screwed into the socket so turn it counter clockwise and see if it comes off. When replacing the light bulb, press the door switch to ensure no power is going ot the bulb socket to prevent it from damaging the new bulb.
Mar 07, 2009 | Ovens
Can't figure out how to change the light bulb in the oven
normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
Nov 25, 2008 | Ovens
Changing the light bulb in the oven
the light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
Apr 21, 2007 | Stoves Premier 720GRa Gas Double Oven
KitchenAid KEMC378KSS Electric Double Oven Logo
996 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
