Question about Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 1270 "Check Paper"
"Check Paper" remains on screen. Not able to clear. There isn't paper in the machine. Follwed the manual after paper jam.
  • Briansong Mar 15, 2008
    unpluging the machine does not work for me. Thanks
    Sergeant:
  • 201 Answers
    President:
  • 2,072 Answers
You more than likely have a sensor issue.
First thing to do is unplug the machine and remove the cartridges.
You want to note the entire path of paper travel, from paper tray to outout tray. You need to look for a couple of things.
1. A small piece of paper, most likely in the fuser. Just takes a small piece of paper on a sensor to keep it shut down.
2. And what I suspect more is a dislodged sensor flag. Look carefully for black channel sensors in the paper path. One of the flags is, A. knocked of and needs reset in the clips, B. One of the springs on a sensor has come off and it is not returning to it's home position, or The sensor is stuck in the slot where it hangs into the paper path.
What will solve this problem is more slow and close inspection of the entire paper path. Once again, carefully inspect the path from where the paper feeds in to where it exits totally.
Posted on Mar 13, 2008
    Scholar:
  • 58 Answers
Unplug the device and let sit overnight. This will reset configuration and should fix the problem. If it still persists, contact the manufacturer's support. They will be able to help, especially if they are faulty sensors in the machine.
SOURCE:
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
I recently cleared out a paper jam from my printer / scanner / copier. Although I can scan and copy just fine, when I try to print something, I get an erroe message on my screen that says "Paper...
Hi. The error message shown as paper jam cleared a) not fully b) not carefully and there is any paper fragment or a whole page remained yet. The sensors are perceive the paper in the paper way, so there are any dirty thing or paper fragment. Read again the user manual, section of paper jam carefully and try to clear out again.
Sly
Nov 22, 2010 | HP Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Check Display
usually it's a paper jam. remove cassette, and look inside...there may be a piece of paper stuck inside. Also remove, and re-seat all paper in the cassette. Also, remove toner cartridge, and check inside the machine cavity for jams..
re-post if problem remains.
Jul 15, 2009 | Ricoh FAX2050L Plain Paper Laser
Error jam code
check for any remaining of torn small pieces of paper===check for no pins or other things inside in paper path=====check for free actuation of paper switches and the lever of the switches in a good condition ------later shut the machine off and then on.
Apr 06, 2009 | Sharp Office Equipment & Supplies
Paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Dec 07, 2007 | Panasonic Workio DP-2310 All-In-One Laser...
Brother IntelliFAX 1270E Plain Paper Fax Logo
328 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
