When I turn on the monitor it is completely white and blank I have to turn it on and off at least 20 times then I get a faint screen back.
    Sergeant:
  • 349 Answers
Use another monitor to establish if it is the monitor or the video card.maybe a friends.
both can be replaced at minimal cost
good luck
Terry
Posted on Mar 15, 2008
Try your monitor on another system (friends) or use friends on yours this will tell if it is the monitor or the video card,
good luck
Terry
SOURCE:
My screen goes blank when monitor is turned on.power light on monitor stays on. What is the problem?
If you look at the screen at a sharp angle and you see a faint Windows image then the problem is a back light fault. This fault can be caused by a faulty inverter board that supplies high voltage to the CCFL lamp OR the CCFL lamp is faulty. The CCFL lamp is a very small diameter fluro lamp/tube and just before they fail completely they product a pinkish light.
Replacement inverter and CCFL lamp are available from this WEB site.
www.lcdparts.net
Jul 03, 2011 | Samsung SyncMaster 205BW LCD Monitor
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
E manchine e17tg turn on power you get just a
mrmadgbull, How long will e17tg display the WIN-desktop before it goes to BLACK screen? Is it 1, 2 ...4, 5.....20 seconds? How old is unit? Does unit have internal ac to dc SMPS or external (lay on floor) SMPS? Did problem occur suddenly? What do you see on screen after "it" goes black and you shine a bright flashlight 1 inch from screen? Can you still see some icons being faintly displayed?? Is unit out of it's warranty period? If lcd panel is both black and blank, "switch-mode-power-supply" could be in full shutdown mode. If you see desktop, SMPS is in partial shutdown mode. You or electronics technician will need to evaluate and repair unit. Read my FIXYA profile for more options you may have open to you. Your monitor no different than any other "cold-cathode-fluorescent-lamp" backlit LCD monitor. There is a lot of DIY videos on YOUTUBE that deal with this type of monitor problem. Lots of tech types pick-up "black screen" lcd monitors at resale shops and refurbish them for less than $20 total cost, and they will work for another 2 -4 years. Do your research before making hasty decisions. If pocket is deep with disposable income, then just use e17tg as trade-in for new wide screen. Hope this was of some help. 12fixlouie
Jan 28, 2010 | E-Machines E17T 17" Flat Panel LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
Fujitsu Siemens lap top AMILO l1310G
Try reconnecting the LCD cable on the back of the screen. You have to open the screen in order to access the lcd cable.
If this won't work, the cable is most likely not working correctly.
Oct 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sidekick id screen
Seems you need a new Lcd assembly i can provide you with one very cheaply please contact me at [email protected] I can sen you a new Lcd or u can send me the phone for repair
Jul 21, 2008 | T-Mobile Sidekick ID Cellular Phone
Turn on monitor green light but blank white screen can faintly see windows underneath. Have to switch on and off at least 20 times to get a screen. Is it the monitor or the video card?
Could be either but most likely the monitor or cable depending on your setup. Hate to say it but the only way to tell is to try replacing one. The monitor is the easiest. (If you buy one and it doesnt fix it, you can always return)
please rate.
Mar 18, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
46 people viewed this question
Ekse
Marvin
Marvin
