Question about West Bend 33600 Coffee Maker
36 cup coffee maker
When I fill the coffee pot and let it perk, there is alot of grounds in the pot.
What do I do about this. We have another one which is a 42 pot and we have never had this problem. Thank you.
annapat74@embarqmail.com
    Scholar:
  • 67 Answers
Are you using the correct size paper filter for the basket? Are you putting too much coffee in?
Good luck.
Posted on Mar 14, 2008
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
What does it mean when the brew light flashes?
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Mar 25, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Need directions for the Micro-Perk microwave coffee brewer
i recently bought a microwave coffe maker and it also has no instructions,,, help its from a company called colony...
Sep 19, 2009 | Faberware FCP240 Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
No Coffee
do not fil the pot past 8 cups, you have to give some space for the water to circulate while running the cleaning solution.
Mar 28, 2008 | Faberware FCP412 Coffee Maker
Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Nov 07, 2007 | Faberware 12-55 Cup Coffee Urn
West bend coffee
flip the unit over and use a 5/16" nutdriver to remove the screw. carefully pop off the base. look for the heater wire that's wound around the main heater. it may be burned off the spade connector. the pilot light operates off the little thermal device that's held in place with that flat spring. the other side of the main heater is welded to the heater and the cord terminal. the thermostat device may be shot - it should stay open until the pot is filled with hot coffee. it is set to close on a preset temperature of the pot. replacing it should solve your problem.
Aug 19, 2007 | West Bend (58036) 36-Cup Coffee Maker
West Bend 33600 Coffee Maker Logo
81 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
