SOURCE: SONY DVP-S7000 does not play DVD
All reviews that I am reading confirm my belief. It is a 1st generation DVD player and therefore will be hard pressed to play any newer DVDs. Think of it as technology advancing. It's sad but it happens. Even newer DVD players can not play the types of movies being developed today. i.e. BluRay discs. So if you cleaned it and you can play picture discs chances are you're going to have to sacrifice which movies you can watch and search for those it will play.
SOURCE: Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
SOURCE: RDR-VX530 will not play DVDs rented from Video
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
SOURCE: i can't hear the voices when i play dvds
Change your audio setup to stereo. if you are running two speakers
