Computer Repair How do you open the case of a Maxtor One Touch III External USB Hard Drive
  • SavageTJ Mar 13, 2008
    We're talking about the USB box here, not the IDE or SATA drive itself inside.
    Genius:
  • 3,587 Answers
You don't..that's factory level only, mostly due to the clean room requirements for handling the naked hard disk
Posted on Mar 13, 2008
SOURCE:
How to repair the usb port on maxtor one touch 120GB external drive
You cant repair USB its to small to resoldure unless you are PRO, you could take it apart and connect it to a computer or another laptop and pull out the data here is a guide. http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Reusing_the_Maxtor_OneTouch_III_Mini_Edition_Portable_Hard_Drive
Mar 06, 2011 | Maxtor OneTouch III Mini Edition 120GB...
I had problems with my Maxtor One Touch III Mini. It was a loose connection from the USB cable on the Drive's end, and when I tried to solder it, I damaged the connector. Is there an alternative to get an...
If you damaged the external case you have two options. Remove the drive from it and put it in a new external or put the drive directly into your computer.
Here is a guide that will show you how to open your case.
If the hard drive is a SATA DRIVE you can just plug it right into your computer with SATA cables. If your drive an IDE DRIVE you're going to have to find an adapter in order to plug it into your computer as the IDE connection on these smaller drives aren't the same size as the connections on normal sized drives.
The easiest solution would be for you to find out what kind of drive it is, and then buy a compatible external case to put it in.
Mar 03, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My Maxtor One Touch III no longer turns on. The
well after some research or a lot of research. I found a few articles that suggest that there is a problem with the board inside the case. It suggest that you take apart the case and remove the hard drive and put it into your computer and it will work just fine.
Nov 04, 2009 | Maxtor OneTouch II external hard drive...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Computer is not detecting my maxtor onetouch III
the hard disk interface could be broken, open the hard disk case and use it as an internal hard disk as a slave in a computer to save your data
Oct 27, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Computers & Internet Logo
55 people viewed this question
Ekse
Alun Cox
