Question about Gateway FPD2275W LCD Monitor
Samsung SynsMaster 939B
Have two of the above monitors. Had to discuss my computer for repairs. when it was turned on both monitors would turn on but the work product would only go to one monitor. could not work off of both monitors. then discovered if went to the lower left hand corner of one monitor could get other screen to work. Please advise as to how can just pull the work sheet to the other screen.
Thanks
    President:
  • 2,351 Answers
With your work sheet opened (reduce its size by clicking once on the Square in the right hand corner of the page, just make it a bit smaller than your screen), than left click & hold drag it to the second monitor. Once there you can maximize the page to fill the screen.
If you post back with your video adapter information I may be able to help with other settings for your video card. You can find this information by opening control panel, open System. Your display window will open. Click on the settings tab. Than click the Advanced button. Click the Adapter tab in the next window.
Your Adapter Information is listed there.
Godd Luck!
Posted on Mar 14, 2008
My SynsMaster 2220WM computer doesn't turn off. It
It says what?
You can always remove the power cord and press and hold the power button until is shuts off.
Apr 26, 2012 | HP Computers & Internet
Monitor turns on for about half a second, then screen shuts off
There is a power supply problem and inverter board issue, cause usually bad capacitors in the above mentioned, sometimes they bulge at the top indicating they are open, repairs can run to the point that it may be cheaper to replace the monitor.
Mar 04, 2011 | Samsung Syncmaster 940BW LCD Monitor
Syncmaster 203b power light comes on, but no image...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Samsung SyncMaster 203B LCD Monitor
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Same problem not optimum mode recommended mode 1280x1024 60hz
hope this is helpfull http://www.ehow.com/how_4758816_repair-samsung-lcd-monitor.html for me it was
Jan 24, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung syncmaster 713bm
This problem is caused by a fault with IC200 on the main board, this seems to be a common failure with the Novatek chip and can only be replaced by a repair company as the new chip needs to be reprogammed and it is also surface mounted.
Nov 13, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
227 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
