Question about Bosch Axxis WFL 2060 Front Load Washer
Door Handle/Lock for Bosch Model # 2090
I need a replace handle/lock as it is broken. I bought it in Mexico but have my machine in US. Where can I buy the part? Thank you
  • 1,294 Answers
Posted on Mar 13, 2008
  • prem mathew Mar 14, 2008
    Go to the above site to order your part, it will be delivered by post.
  • prem mathew Mar 16, 2008
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
Aug 22, 2013 - Uploaded by
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Hi, I have a Bosch SMS 4012 dishwasher. It's about 20 years old but looks (inside anyway) as good as new. It's only the design that ages it really, it's been brilliant and I'm loathed to replace it but I...
Hello Pauline,
The handle and latch/lock are sold separately but both are still available direct from Bosch. This model was sold in the UK and Australia, but I'll assume for the moment you are in the UK and provide details for for ordering parts in the UK.
Plastic handle for Bosch SMS4012
Bosch part number: 056219
Price: £5.12
Lock for Bosch SMS4012
Bosch part number: 056218
Price: £19.13
Both parts are in stock and ready to ship. Bosch have a standard delivery charge of £5 per order.
You probably only need to order one of the above parts. You said it wont open/close, so you probably only need the lock unless the plastic handle is cracked/broken as well.
With regard to replacing it yourself, it's fiddly and requires some dis-assembly of the door and control panel but it can be done on a DIY basis if you're patient, practical and you know the difference between a pair of pliers and a screwdriver ;) (you'll need both)
It's not the most difficult job on the washer but it's not the easiest either so you may want to consider calling a professional. You could also order the parts yourself and pay someone to fit them as this usually saves a bit of money, but you should inform them beforehand that you will be doing so. Some engineers make extra profit on the parts and aren't keen on having the parts supplied!
Either way, the parts are still available so the dishwasher can be repaired. If you are not in the UK please let me know, but the part numbers should be the same wherever you are.
If you decide you want to try replacing it yourself, I can provide further guidance, but this washer was made before I started repairing dishwashers and I don't see many of these washers now. It's one of those repairs I could do if I had the machine in front of me but providing step by step instructions without being able to see it is a little more difficult - but not impossible! You will probably have to figure out one or two bits for yourself . . .
Hope this helps. Please let me know if you would like further assistance.
Mar 16, 2011 | Bosch Dishwashers
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Aug 22, 2009 | Washing Machines
Cannot open door from inside on front driverside
29 cent part my fix your problem. There is a nipple on the interior door lock lever that fits into a slot on the door handle lever. Look at passenger side to compare. The nipple is covered with a plastic spacer that may come off. The spacer keeps the lock nipple snug in the handle lever slot; pull the handle lever, it engages the lock lever, opening door. I bought a .29 cent aluminum spacer (#8x1/4 x 1/4) from Orchard hardware. Take needle nose pliers and slip the spacer on, then super glue. Unfortunately if lock lever (where riveted) is badly worn, then it may pivot upward instead of perpendicular to the door, thus defeating new spacer. But you may now be able to open door by pulling handle lever and lock lever at the same time. If you need to replace door handle, others on this site have suggested that you not replace metal frame that door handle is mounted on, but drill out rivets that hold door handle mount.
Jan 29, 2009 | 2001 Lincoln LS
Driver's door won't lock remotely after driving.
Your Beetle might be German in name only, those things are built in Mexico.
Jan 19, 2009 | 2005 Volkswagen New Beetle
Door handle replacement
I tried different ways of putting the door handle and lock together. It took me 5 hours to eventually work it out. Now the problem is solved.
I took a digital photograph of the lock before I put it back onto the machine, so now I have a permanent record to refer to next time. I say next time, because we've had 2 Servis Washing Machines, and between the 2 machines, the door handle has broken 4 times, through no fault of ours, each time having waited for the time switch to deactivate.
I think by now the company ought to make the plastic piece that keeps snapping, out of aluminium.
Sep 12, 2008 | Washing Machines
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
304 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
