Question about Sewing Machines
BOTTOM STITCH IS ALWAYS LOOSE
CONSEW CN2053R THE TOP STITCH LOOKS FINE BUT WHEN YOU FLIP IT OVER THE FABRIC AND LOOK AT THE BOTTOM STITCH IT IS LOOSE LIKE LITTLE LOOPS INSTEAD OF TIGHT STITCHS. I HAVE TRYED TO TIGHTEN TE BOBIN SREWS BUT NO CHANGE.
  • 1 more comment
  • Anonymous Jan 15, 2009
    bottom stitch is loopy
  • Josh Wick
    Josh Wick Mar 26, 2014
    Make sure the PRESSER FOOT IS DOWN! Oh my gosh, it took me 2 days to figure out why my bottom stitch was loose. It was driving me crazy...then I read the manual :/ I hope that helps!
  • Julia Wood
    Julia Wood Feb 07, 2018
    Wow! Your question takes me back ages! Hope you've found a fix! I have an industrial Consew, so - your bobbin case is loose. Very loose! It seems you know how to tighten your bobbin tension. Just turn it tighter, and check every 1/4 turn, until you get a stitch where top and bottom threads meet in the middle! Cannot believe you've not gotten help in Years! Love my Consew! By my calculations, it sewed 1/4 mile in building a Civil War dress. And it is Fast! Love mine. You seriously need yours to Work!
My top thread is pulling thru to the underside..looks like little birds feet tracks on the back of the quilt...help
Posted on Aug 09, 2008
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Posted on Mar 14, 2008
  • Sewing Machines Master
  • 12,648 Answers
Actually, the majority of recommendations are incorrect. If the bobbin thread is loose, it's because the top thread is not high enough to pull the bobbin thread up.
Tension is a tug of war. Correct tension is when both threads exert equal amounts of pull against each other, the result causes the two threads to meet in the middle of the fabric. In your case, the top thread is exerting zero pull on the bobbin thread so the bobbin thread simply lays on the surface of the fabric. Raise the top tension and see what happens.
Posted on Feb 07, 2018
I have a Barnett 50 sewing machine and my bottom stitches are very loose . Where do I go to tighten then tension for the under part of the stitches.
Posted on Feb 03, 2014
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
Tension setting model lx2763how to set the tension top stitch looks good bottom stitch is loose
top tension is incorrect
pull the top thread out and there should be resistance to pulling it before you thread the needle
Nov 11, 2017 | Sewing Machines
Consew machine. My bottom thread has ball knots on the bottom. I have changed the needle and the top stitch is perfect. Please advise.
Re-check the thread that is knotted. It's most likely the top thread causing what is called thread nesting or what I term "thread barfs."
Thread problems appearing on the top of the fabric are generally caused by the bobbin thread. Problems appearing under the fabric are usually a result of upper thread issues.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the upper tension to the midway point.
http://www.superiorthreads.com/blog/2015/8/what-causes-bird-nests/
Apr 19, 2017 | Consew Sewing Machines
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
Stitch looks great on top and bottom has loops and loose
try adjusting the top tension one number or letter higher till the stitch looks normal
change the needle
May 11, 2012 | Consew Sewing Machines
Top sew is great bottom has loops and is not tight
change the needle
adjust the top tension one number or letter at a time higher till the stitch looks normal
check to make sure the bobbin is inserted into the bobbin case correctly
May 11, 2012 | Consew 206RB
I always have problems with loading the bobbin, when I think it is loaded properly and begin sewing, it balls up and doesn't stitch properly on the back side of the fabric. Top stitch is fine, underneath...
the bobbin case has a small screw on the side for adjusting the tension, use a tiny screw driver to finely adjust the tension and sew on a scrap until the stitch looks good always turn the screw clockwise to turn the tension up and counter clockwise to loosen it
Dec 13, 2009 | Bernina Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
2,354 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
