Kitchen Ranges Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dimensions (especially depth) for Magic Chef 31213XAA gas range
Do you have dimensions (especially depth) for the Magic Chef gas range model 31213XAA? Thanks.
electronic & computer repair& servicre
Level 3:
  • Kitchen Ranges Master 12,061 Answers
  • Posted on Mar 28, 2010
Level 3:
Answers
12061
Questions
0
Helped
4008031
Points
36390
Www.magicchef.com/
Please get a manual from the above link. Or contact them. usually the dimensions are about 24" depth
2answers
I need to know the dimensions of my kenmore 106.57026601 st3432509
The dimensions of the Kenmore refrigerator model 106 are known according to their height without hinges as 65 ? in. and with the hinge as 66 ¾. In addition, they are 32 ? in-depth without handles and 33 ? in-depth with handles. https://homeguideinfo.com/kenmore-refrigerator-model-106-dimensions/
https://homearise.com/kenmore-refrigerator-size-model-number/
1helpful
Anyone happen to know the dimensions of magic chef fridge?
Question moved from Garden category.
Dimensions · H 59.4 in, W 23.6 in, D 25.2 in ; Appliance Type, Compact Refrigerator ; Color - Appliance Cabinet, White ; Color - Door Handle(s), White ; Color/Finish
How many cubic feet is it?
measure the internal dimensions--- width X height X depth and multiple the measurements to get what you want
simple maths
What is the Cu. Ft. of my Magic Chef Refrigerator Model # RB193AV? Previously put Model # in Select a specific product, 1st time on fixya
Hi Jim,
Because this is an older model and the CU feet many not reflect the size you can now fit with newer models (better insulation, etc.), I'd suggest going by the dimensions of the opening and allowing for the manufacturer's recommended clearances.
If you need further help, reach me via phone at https://www.6ya.com/expert/roland_e8cd37f59424d315
What are the cutout dimensions of a Magic Chef 59GN?
Need to find out what size oven to buy to replace Magic Chef : 59GN -5TVW
2helpful
I am trying to replace my old slide in gas range (Magic Chef- model # 6498XTS with a new slide in gas range and am trying to find out if the new one will fit where the old stove was, here's my problem the...
The installation depths provided in the installation literature, are the minimum requirements for fitting the slide in range into place. You need to determine what the depth of your opening is where you intend to install the appliance. The depth shown on the installation instructions might be showing the overall depth of the appliance, including the oven door, which typically sticks out from the cabinet anywhere from 1-3 inches, depending on the brand, model, etc. The old Magic Chef might have only provided the needed depth for the oven body, and might not have included the front oven door projection, past the countertop, etc. Most cabinents are about 24 inches deep, so anything larger than that, will likely stick out into the room more, unless your cabinents are deeper than 24", you're looking at having the new slide in oven stick out past the front cabinet front/edge, by about 4 5/16". I'd make a cardboard template to the dimensions of the new oven and use that to see just what you're facing with the replacement oven. It could be possible that you've confused the depth with the width for the new oven, as I've not seen many ovens that are as large as 28" unless it was a Viking, or other really high end, professional style oven, etc. Check your installation dimensions again for the Maytag and make a cardboard template to confirm how much space will be needed. The good news is that you can remove the old Magic Chef, since it's not working, to allow you to make a more informed decision as to fit and clearances required for the new oven. Just be sure to disconnect the power to the range or unplug the power cord, if that's what it has, before attempting to remove the slide in. Hope you find this Very Helpful and best regards!
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
