Question about Xerox DocuPrint M750 InkJet Printer
Changed all ink cartridges and now will not print, just flashing red light
HI
I have been given a second hand m750 which worked fine when I got it, just needed new ink cartridges. Now I have installed them, but it will now not print, all I get is the red light blinking slowly. I've tried putting the old cartridges back but the light is still blinking at me!! Help!
    President:
  • 2,072 Answers
It sounds like the connections on the cartridges have some ink on them.
Remove the cartridges, and take a lint free cloth, slightly dampened with alcohol. Look for all the contacts and gently clean them. You may have to do that more than once to break down and remove all the contaminents from the contacts.
Then look through the memory on the printer for a procedure called Memory Clear, and perform that. That will remove any corruption in the printer memory/software. You will have to set the printer back up once you perform a memory clear.
Make sure you clean the print head area with the printer unplugged, not just turned off. Make sure all the power is removed.
Posted on Mar 16, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Epsonstyluscx3810printer
I had the same problem and I could not print read. I cleaned, put in new ink etc. Here's the kick.... I ran a nozzle check and noticed that the red and the cyan ink cartridges were reversed! I switched them and it worked fine. I don't know it that is your problem but it blew me away... such a stupid mistake, putting the ink in the wrong places.
GJean
www.bacaracka.com
Oct 11, 2007 | Epson Office Equipment & Supplies
Xerox DocuPrint M750 InkJet Printer Logo
174 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
