Question about Toshiba Satellite A105 Notebook
New Laptop Optical Drive Causes 0203 failure ide #2 error at boot
I installed a replacement optical drive on a client's Toshiba notebook with a supposedly compatible drive when the original drive stopped reading discs. Now, upon boot up, the error "0203 failure ide #2" appears and the new drive is not recognized.
It appears that this is a IDE master/slave issue from the research I've done. Unlike a desktop drive, this laptop drive does not have jumper settings to set master/slave. I am certain it's something with the new drive; the old drive is detected fine, it just doesn't work properly otherwise.
Any suggestions? I'm probably going to return the drive as incompatible if I can't find a viable solution.
Thanks,
Jeff
I had the original drive and was able to remove the tray (read head most commonly is where the problem is) from the new drive that was giving me errors and install it in the known good config. It was really easy to do if you have a tiny Philips screw driver. Remove the top of the drive, then carefully follow the ribbon under the drive, remove the screws on the plate over the ribbon, pull the retainer to you, then gently pull the ribbon out of the retainer. You have to gently manipulate the sliders out of the case and they are very fragile, so take caution in removing them, but it can be done. Put all of the parts from the tray out into the old drive and if you have the same results as me your boot error message is gone! ;)
Note: on the original drive there was really clear tape that held it together after removing the screws, so watch for the tape, once the tape is removed the top comes right off.
Posted on Dec 06, 2011
    Genius:
  • 3,587 Answers
It's in the bios, hit F2 when it's booting, and go to drives, and set it from there..you will see them..you may need to turn them off, and then restart, then F2 again, and then turn them back on.
check your computers warranty here 4 FREE
Posted on Mar 13, 2008
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
The Laptop Toshiba produces an error when trying boot from the bootable CD & an error occurs. error 0203 failure IDE #2
Try re-burning a new copy of that bootable CD. It's possible the Bootable CD didn't burn correctly or maybe the image is bad.
Jul 24, 2012 | Computers & Internet
Error 0203 failure IDE #2
Arthur,
That problem can be a couple of things.
The CD/DVD Drive may be failing ,or the actual IDE Controller built into the motherboard is bad.
You will need to determine which it is.
To do that - find an identical computer and see if you can remove the CD/DVD Drive from your laptop and swap it with that computer's drive. Then try to boot up your laptop with the "Known Good" drive in the system. If the same error occurs - then you will know that the IDE Controller on the motherboard has failed.
You can try to upgrade your system BIOS and this might trick the IDE Controller back into working, but it is a slim chance. Try it anyway.
(For details about swapping the CD/DVD Drive on your laptop, visit the toshiba website to get the instructions. Also, on the same website you can download the BIOS executable to attempt to run. The website is: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=556042&rpn=PSM30U&modelFilter=M30-S350&selCategory=2756709&selFamily=1073768663)
Hope that helps!
Nov 26, 2011 | Toshiba Satellite M30 Notebook
Error loading operating system amessage appear on toshiba satellite A15-S127 and operating system cd on dvd and it didn't boat from dvd what can i do? or how can i enter setup
So you have a potential problem with the hard drive and a known problem with the optical drive. Replace the optical drive first: it's easy (one screw at the bottom, another one underneath the keyboard - these are the only 2 screws holding the optical drive in). You can buy a replacement drive, new or used, on eBay for $10 - $20 delivered. After that, you should be able to figure out if the hard drive's problems are OS related or HW failure. HDD's are cheap, too. This model uses 2.5" ATA IDE drive (30 or 40G or you can go larger), figure 50 cents to 75 cents per gigabyte, and you'll be okay. Just don't pay tourist prices for these things....
Apr 21, 2011 | Toshiba Satellite A15-S127 Notebook
AM GETTING AN ERROR "0203
First try restarting while tapping the F8 key to try and both from disk this way.If that doesn't work you will need to try and install the drivers for the ide controller and cd rom . if all else fails you may need to try replacing your dvd/cd drive it has failed for one of the above reasons.
Dec 01, 2010 | Toshiba Satellite M35-S456 Notebook
Select bay error
Try restarting the notebook and press F2 to get to the BIOS and look if the optical drive was detected, if not place the WIndows instalation disc into the drive then reboot the laptop and press F12 then chose to boot from CD, then press any key to start the instalation of Windows. Agree by pressing F8 then when you are asked what would you like to do press install Windows, on the next screen you will be asked again what action would you like to take, chose to repair the existing windows, and follow the onscreen instructions, this will not delete any files on your laptop but will infact repair windows. By chosing to install new windows, at the start the system will load the default drivers which infact will reisntall the CD /optical drives. Also before you try all this you could just go to Device Manger and check if any drivers are market with red "X" or the yellow exclamation mark under the DVD.CD drives. This should resolve the issue as it seems to be that windows is corrupted and cannot load the optical drives or detect them. Good luck
Apr 29, 2010 | Toshiba Tecra S3 Notebook
Will not boot up
From what you describe, you may have a HDD failure. The Inspiron 8000 has a serial bus for the IDE drives and if one drive fails neither will work (If HDD Fails, the CD drive will not read)
Reseat both the HDD and Optical drive and make sure they are detected in BIOS. If HDD is not detected, replace it.
Mar 11, 2010 | Dell Inspiron 8000 Notebook
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
PXE-E61 Media Test Failure PXE-M0F Exiting PXE ROM
the laptop not recognizing the boot devices except the network boot that it found but there was no connection so it exit the pxe rom. first you need to open up the laptop and see what is running around inside maybe metal and your in for trouble if its metal maybe screw or so. second and this will hurt but you may need a new motherboard.but first lets get the object out.metal or plastic so you'll need to pull down the laptop and take the cmos battery out for abit .put the laptop back together replace the cmos battery leave out the hard drive and the optical drive (cdrom,dvdrom) then turn the laptop on wait for it to boot then turn off. replace cdrom with bootable cd inside restart. if it boots your in luck.turn off replace hard drive and restart. If all goes well and your able to boot to hard do this first download the bios flash for you laptop at toshiba site only at toshiba site and only your specific laptop model. read the readme file that come attached follow the instructions. then you can do you upgrade that you wanted to do all along
Jul 02, 2008 | Acer Aspire 5100 Notebook
Cd will not play
Please test your Optical Drive with any bootable Cd/DVD if it gets successfully booted from CD/DVD then your Optical drive do not have any problem.
but if it is not sensing the CD/DVD in boot sequence also then there might me problem with your optical Media Lense also.
You need to replace it
May 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 Notebook Logo
1,025 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
