Question about Samsung SyncMaster 740N 17" LCD Monitor
DEAD SCREEN THERE WAS A POWER FAILURE IN MY AREA AND MY COMPUTER ALONG WITH MY LCD WENT OFF.WHEN I PUT THEM BACK ON THE COMPUTER WAS WORKING FINE , BUT THE LCD WAS ONLY BLANK,IT WAS COMMING ON THOU,BUT WASNT PICKING UP THE COMPUTER IT WAS JUST BLANK,NO WARNING ICONS,(NOTHING AT ALL)
  • mckay14 Mar 27, 2008
    i have had 2 of these monitors both after about 2 years go black. i shut them down for the weekend come back and turn them on and nothing just dead unpluged tried on different cpu that was working for sure still nothing. i have 6 stations at work. 3 are Dell been working for 5 years +.the other 3 were new 2 years ago all had the samsung monitors down to one. just woundering if this is common with samsung,and if theres anything i can try to fix them? my monitors are all syncmaster 740B 17" lcd monitors
  • Samsung Master
  • 19,396 Answers
Disconnect completely computer and display form power cable for ten minutes, plug them back and restart ().This is called hard reset.
If you still have the problem try checking the display video cable, both in the monitor and computer socket.
If it still does not work connect PC to a different monitor, just to test that is not the pc or the video card the problem.
If it still does not work the blackout may have caused a short in your monitor or a system failure on pg then get back here and post the new problem.
regards
Posted on Mar 13, 2008
I have a Compaq CQ61-411 Notebook the battery went out the computer was working great but a message came up saying replace battery and it cut off and would not charge back up so it took me a few months to...
HP.com
see your manuals and what the blink codes mean.
each PC has PDF manual that covers that.
blink codes are BIOS warnings.
to tell you what catastrophic failure happend
like low power
bad memory
processor dead
GPU dead.
and more, some have 12 errors possible (newer)
if the BIOS screens are dead, its lost power.
or one of the above.
Mar 20, 2017 | HP Compaq Presario CQ61410US Notebook
My HP monitor was working fine then randomly one day it went dead, I turned it back on and I could see the screen and what it displayed for about 2 seconds, then the screen dies again. The power button is...
Sounds like your monitor is going dead. If its under warranty that would be the best way to go. Specifically it sounds like the power inverter is dead or there is a busted capacitor.
Mar 12, 2011 | HP Pavilion F1703 17" LCD Monitor
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Suddenly crash and cannot reboot
HI do you need my HELP please post
Sep 06, 2008 | Dell Inspiron 6000 Notebook
Dell E151FPp 15 TFT LCD flat panel dim
Do you have the same issue when the cable is disconnected from the computer? If so, and the the brightness function doesn't change, then you have an IC Chip failure and the replacement boards are not available to you or me as Dell is Dell and everything from them is proprietary. If you are under warranty pursue that if not, time to replace. Consider this a time, unwanted time, but time to upgrade.
Oh, your right about the sacrificial diode on the power card... you wouldn't see anything.
Hope this fixed ya.
Regards,
Worldvet
May 15, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Power
check the power pack to see if it has the required output voltage, usually 12-15 volts. solidstate power packs are prone to failure. The LCD screens require between 2 and 4 amps to power them. A strain on some power packs. Gary(Honkity Hank)
Sep 18, 2007 | AOC LM929 (Black) 19" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
482 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
