Question about Refrigerators
Water in the drainage channel at back of refrigerator box freezes so that water cannot drain away.
    Novelist:
  • 87 Answers
Would check first that the drain is not blocked (typically with a straw down the centre hole and blowing hard). Then check the thermostat is not making the cabinet too cold to allow constant ice formation. Doesnt sound like a major fault. If not the above try defrosting and start over. Hope this helps.
Posted on Mar 13, 2008
For the last 4 months water has collected in and under produce bins where is freezes if not mopped up. I've tried pulling items away from shelf vents. Could a drain be clogged?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
I have a Kenmore Elite Model 795.7105. A plumber used bread on a water line to dry a connection and repair a leak. Now the water dispenser is very slow. I removed the filter and inserted the bypass, but...
Mar 27, 2015 | Kenmore Refrigerators
How do I defrost the water line to ice maker on a Kenmore Coldspot model 5151200
Feb 24, 2015 | Kenmore Refrigerators
Water freezing on floor of lower draw under ice maker
Dec 05, 2014 | Refrigerators
Samsung RS275. Water pooling under bottom drawer and freezing. What doesn't freeze, leaks through the door to the kitchen floor. What is happening?
Jun 26, 2014 | Samsung RS275AC Refrigerator
Water dripping from freezer
May 07, 2014 | Samsung RF4287HARS Stainless Steel French...
Unit is leaking in the house has been serviced mult times and the drainage tube going outside home is draining and has been recently cleaned out.
If your drain is clean and it is still leaking, the water pan below the evaporator could be rusted out or depending on the installation make sure the coil box is not slanted away from the drain stub on the coil. Also check to see if the evaporator is freezing up due to low refrigerant or dirty filter.
Apr 10, 2011 | Heating & Cooling
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking out of the bottom of the interior of our Contour Refrigerator.(HE430TF) It does not appear to be flowing into the defrost overflow tray. I have poked a piece of fexible plastic up the pipe...
Hi Richard,
I don't have any knowledge of your particular model but on mine the water condenses on the cold plate in the fridge compartment and then drips down into a little channel. From there it goes down through a fairly small tube which opens onto a little dish formed on the top of the compressor unit. This unit is warm when running, and the water is supposed to evaporate away into the room.
If water is collecting on the floor of the fridge compartment it is almost certainly due to a blocked drain pipe. If the drainage channel has become cracked this might be another cause of your problem.
One way to check that the drainage pipe is clear is to blow up it (not blow it up !) but that is a pretty yucky job. Alternatively you could pour a little hot water with dishwashing detergent dissolved in it into the drainage channel and check that it comes out onto the compressor top.
I hope this helps, but if not please defer a rating until we have had another think about it. Cheers, D.
Jul 09, 2008 | Hoover Refrigerators
Ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Apr 02, 2008 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
