Question about La Crosse Radio Controlled Atomic Clock
Set the clock to DST
I have a model WT-3143 wall clock. it won't set to eastern daylight time. I put a new battery in and it set to eastern standard time. How do I get it to set to daylight time. By the way, there was no manual with the clock so I have no trouble shooting guide.
Thanks,
Carroll
  • Anonymous Mar 16, 2009
    Ever since change to DST, clock can not be adjusted to Eastern Time, it is always one hour behind. Tried all fixes listed on their website, and am now waiting for customer support to return my voice mail and email.
  • Anonymous Mar 23, 2014
    clock will not set to daylight savings time
    Novelist:
    Champion:
  • 225 Answers
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
Posted on Mar 26, 2008
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do I change to daylight saving time?
Your clock may have failed in a way that new batteries won't help.
Apr 04, 2015 | La Crosse Technology Atomic Wall Clock -...
Hands rotate endlessly onatomic clock wt 3143
If you have not talked to La Cross and if you continue to have the problem, most likely it may be a signal problem. I had a similar
problem with an earlier model and found that it only worked on
the west facing wall as the signal is coming from WWVB which is the NISTtime signal radio station near Fort Collins, Colorado. Get a fresh battery, reset the clock, put it in a west facing window and leave it overnight. If it doesn't work, contact La Cross as above post.
Dec 12, 2014 | La Crosse Radio Controlled Atomic Clock
Need to set time for daylight savings time
You can go to the LaCrosse web site for the answers for your clock
Mar 16, 2014 | La Crosse Technology Wt-3128u 12-inch...
MODEL:WT-8005 CLOCK IS 1 HOUR AHEAD HOW DO I TURN IT BACK?
Check both of these
  • Daylight Saving Time Automatically Updates (DST) (On/Off Option) applies to both USA and UK
  • U.S. Time Zone Selection: Eastern, Central, Mountain, Pacific (applies to USA only)
  • Mar 15, 2011 | La Crosse Radio Controlled Atomic Clock
    Atomic Clock Daylight Savings
    Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
    Mar 10, 2009 | La Crosse Technology WT-2171-UCS Digital...
    Can't change clock to eastern standard time
    Can't solve it but the clock doesn't know the government changed when daylight ends.
    Nov 04, 2008 | RCA RP5430 Clock Radio
    Wrong Time
    This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
    Oct 23, 2008 | GPS
    La Crosse atomic clock model #WT-3143
    don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
    Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
    La Crosse Radio Controlled Atomic Clock Logo
    1,524 people viewed this question
    Top La Crosse Home Experts
    John
    John
    Are you a La Crosse Home Expert? Answer questions, earn points and help others
