Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
"This Device Cannot Start." (Code 10)
This is the reading on my Device Manager. Is the drive dead?
The power supply, although showing 11.7 Volts, was dead or at least very ill. I used a different 12V 2A supply and was well.
Posted on Jul 26, 2008
    Problem Solver:
  • 11 Answers
I had a similar problem with my pc( OS=XP SP2) with the same external drive model. I was able to solve it by downloading and installing WindowsXP-KB908673-x86-ENU Hotfix Package from Microsoft Corporation. I hope it works for you.
Nelson
from P.I.
Posted on Jul 11, 2008
    Problem Solver:
  • 17 Answers
Try Plugging into a differing USB Port, or replacing the internal Hard disk drive yourself, Kind Regards, ACD
Posted on Mar 14, 2008
My Hitachi Simpledrive Mini 250 suddenly quit....when I lookein the device manager it said Code 10, would not start????
Sounds like a disk error and it cant read the start of the drive. If it still detects it you might be able to repair it with a partition recovery or partition repair tool available online.
Dec 11, 2014 | Hitachi SimpleDrive Mini 250GB USB 20...
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
My TS-L 632H DVD Rw drive will not recognize cds. Get the following code on Device Manager: This device can not start (code 10)
firstly u need to check your cables then try different cds, there are sometimes when an optical drive does not read some cds or dvds mainly dvd RW .
the only solution for it is changing the lense of the drive or buying a new one
happy computing
good day
Jun 01, 2010 | Computers & Internet
I have a slimtype dvd a ds8a2s a ata device that I get a code 10 device cannot start message in device manager I have tried to re-install the driver and downloaded any updated drivers and get same message
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Jan 10, 2010 | HP Compaq Presario CQ60Z Notebook
Optiarc DVD RW AD-5170a ata device. Cannot start code 10 error? any ideas why.
Possible cause of the problem:
1. Error 10 means that the drive driver is not properly or not installed in your computer.
2. You drive is broken.
Solutions:
1. Replug your drive wiring's inside the computer casing.
2. Check in the Device Manager in your computer if there is conflict in your drive. Go to Control Panel/System/Hardware/Device Manager to do this.
Nov 28, 2009 | Gateway (5500652) (  5500652)...
Code 10 on HL-DT-ST DVDRAM GSA-T20L ATA Device
Code 10 is a general device failure.
This either means the driver is corrupted or your device has failed.
If you have seen the Code 10 Error you're already in device manager, right click on the device and uninstall it. Once this is done, restart the computer and allow it to reinstall. If it works you're done.
If it doesn't go to www.microsoft.com/kb/341060 then scroll down and click on the "Fix It" button. Restart when instructed.
Lastly if that doesn't work the drive is likely dead, replace it with a new drive they only cost $35-$50 these days.
Hope this helps FixYa,
Chris
Jul 17, 2009 | Computers & Internet
Dvd drive
Remove the drive in device manager, and restart your computer. This will reinstall any necessary drivers
Apr 12, 2009 | Sony Computers & Internet
Cd/rom not working
Try deleting it in the device manager and then reboot your computer to see if it will detect it, then when it asks, point it to the driver.
Oct 25, 2008 | Computers & Internet
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
113 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phillip Whisenant
Phillip Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
