We had the same problem,3 years of every now and then working on it.new ecm lots of other parts,changed ecm relay fuse, started right up.
If there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
SOURCE: have a dodge 1993 b250s replaced fuel pump, now no power
if you have no power when driving or acceleratiing it could be the fuel filter if not replaced could be clogged up. if your getting good fuel pressure to the engine could need a tuneup. if your not getting power to the pump and it plugged in check the ground wire going to the frame from the pump could have a bad contact.
SOURCE: no power to fuel pump 1996 isuzu rodeo
well i got a salvaged ecm from a junkyard and put it in, still did'nt start. took alternator off to have it checked , it is fine. put it back in and now it starts and runs fine. check the alternator and the connections, i heard the alternator controls power after the initial ecm prime when it is turned on. i have no idea how true it is, but worth a shot. if you can find a cheap ecm for a junkyard (mine was 75 bucks) i would try that afterwords.
SOURCE: my 1993 pahtfinder looses power in the 3rd on up
Have you checked for an exhaust restriction? Most garages and exhaust shops can perform a back pressure test for a minimal fee.
Testimonial: "I will try this.. Best lead so far."
