We cannot change the channel on our new tv with the up arrow. You have to manually enter the channel number on the remote before it will work. What's the problem?
    Problem Solver:
  • 12 Answers
When i worked at the game store, one of our lcd tvs would not respond to buttons, only the remote, and we found there was a button lock setting on the tv that could only be changed with the remote. u didn't mention if u were trying the button on your tv or your remote. Keep in mind that i am not an expert and merely stumbled upon your question. if this doesn't help, im sure u will get another solution soon.
Posted on Mar 13, 2008
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: http://s3.amazonaws.com/szmanuals/d29a408ae8fdecdc0547a724183146ef .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Feb 27, 2010 | One For All URC-4605 Remote Control
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Nov 05, 2007 | Philips Magnavox 13MT143S 13" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
