Im Unable to install SSH Server on my XP PC.Need help.
SSH server downloded from "Sourceforge.net".
Config:
XP SP2
1 GB
3 Ghz Intel D
160 GB HDD
Thanks
Riz
Comments:
Mar 13, 2008
- Hi
thanks for your response.
I already downloaded.The Software is installed, but while configuring the SSh tunnel, i need to proxy my SSH client IP address.For that i need to configure it using the COmmand Prompt.I need the Code to configure it.
Hola muy buenas... No me quiero enrrollar asique lo escribire corto... Tengo intaldo en un disco...
(More)
Hola muy buenas... No me quiero enrrollar asique lo escribire corto... Tengo intaldo en un disco duro el SP1 y en el otro el SP3 Que hago para quitar uno de los dos...(Preferiblemente el SP3 lo quiero quitar...porque solo uso el SP1) Gracias de antemano.........
If I do not have a streaming application running my system (XP) will go into standby before even...
(More)
If I do not have a streaming application running my system (XP) will go into standby before even startup has completed. I have changed the Power saving option to "never" standby, but no luck. It seems to be a security issue but I cannot find any setting.
