Question about Motorola Mobility RAZR V3
PHONE ON THE BLINK
MY MOTOROLA RAZR V3 STAY,S POWERD UP & WILL NOT TURN ON THE ICON SCREEN SEAMES TO BE LOCKED.
I received a phone from assurion insurance remanufactured. the prong on the inside where the battery goes was bent girl at att tried fixing now phone just blinks on and off. when * and # pushed simutaneously it gives this message, Can you help me?
BOOT LOADER
0C.C1
SW VERSION:
R3442A_G_0E.43
.0AR
OK TO PROGRAM CONNECT USB DATA CABLE
Posted on Mar 24, 2008
  • 4 Answers
Having the same problem / issue. I would definatley like to know more about this problem. I'll also try to few suggestions and I'll besure to post any reults that I get.
Posted on Mar 15, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Remove the battery,
hold down the * and the # key simultaneously then whilst holding it in, insert the batter, n press power on, give me the info u see on the screen ill tell u what to do
Posted on Mar 13, 2008
SOURCE:
We bought two motorola razr v3's off the internet and they don't have SIM cards. They both blink insert SIM card and emergency calls only. Where do I buy SIM cards?
it may be due to network lock,you can check here http://www.theunlockarena.com/faq/rs13wp27/how-do-i-know-if-my-mobile-phone-is-locked/122/ whether it is locked you can get unlock codes here http://www.theunlockarena.com/motorola-motorazr-maxx-v3/rs13wp9/
you need to specify the country and network provider
Dec 27, 2010 | Motorola Mobility RAZR V3
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
Razr v3 froze up
did you pull battery to clear memory,,take it out and reinstall and turn on,,most likley memory lock, hope this helps
From wendell
Aug 04, 2009 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Motorola RAZR V3 freezes when camera or video is used.
Depending if it has worked in the past, a hard reset may solve your issue. if not you will need to reflash your phone
Apr 19, 2009 | Motorola Mobility RAZR V3
V3 Motorola Razr won't load past Sprint Welcome screen
check software it must be 24-2-00-43r if not this mean it needs software
Jan 31, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3 power on
have the phone firmware reflash from a professional mobile store close to you.
Dec 22, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr Cell phone
This is a common problem, most often fixed by calling your voicemail from another phone and checking the messages. Call your mobile, press * when the voicemail answers, and then enter your pin code. If you don't have any voicemails, leave one first, then call back from the outside line and clear them out.
Dec 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
