Question about Technics SL-1200MK2 Turntable
Skating I have just shipped my turntables from oz to europe. My needles are now skating across the lp when trying to play. I have played around with weights but can't get it to make any difference.
I have the same issue with my sl 1200 mk5s i slightly adjusted the top screw on the tone arm and it has been working fine since..... If you do decide to adjust it MAKE SURE U DON'T LOOSEN IT TO MUCH. Only a hair at a time
Posted on Nov 04, 2008
  • 515 Answers
More than likely your tonearm was damaged in transit. A common issue, especially if you had it in a flight case and not properly tied down, or tied down too tight. You will need to replace the tonearm. Tonearms for this unit are available HERE. Word of caution, do not attempt to replace the tonearm yourself, as it is rather difficult, and you could cause more damage. You'll need to find a reputable repair center in your area. Contact Panasonic - UK for a service center near you (Panasonic is the parent company of Technics).
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
How do I stop needle skating
There are two reasons this will happen first the stylus is so worn it can't stay in the record groove. The second is there is not enough pressure being applied. Generally each cartridge will have it's own required weight. You can look up the model number of the cartridge to see what this is. To set it right however is sometimes a trial and error procces. At the end of the arm is a weight. You should see some numbers on it. You turn this to the number advised for the cartridge. This might be around 1.5 to 2. Then you try a record. If it stays in the groove and there's no rumble sound then you have right. If it's not staying in the groove increase the weight from say 1.5 to 1.8 and retry. Keep doing this till it stays in the groove. If you get to much rumble decrease the weight - again slowly and test like before.
Oct 07, 2014 | Audio Players & Recorders
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
My need on my turntable jumps around on my records
If it keeps sliding in one direction, it probably needs an anti-skating adjustment or to be put on a level surface. If it jumps all over, the stylus weight is probably too light or the surface it's on isn't stable enough.
Sep 24, 2012 | Sony Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Arm and needle skate across the record and no sound comes out. looked at another question regarding this same problem and the response was a possible problem with the stylus or the weight setting. but how...
The stylus should either just clip out or slide out depending on the type of cartridge fitted. On the weight thing look at the other end of the arm. It should have either somekind of screw or a weight with numbers on it. Slacken the weight and move it so the head where the cartridge is gets heavy. If it has numbers turn it to around 2 or 3 or higher and test/adjust using a record till it plays and doesn't make too much rumble sound when playing (in the gaps with no music) with both types of weight.
Aug 10, 2010 | Teac SL-A100 Turntable
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
151 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
