Question about Samsung CLP 300 Laser Printer
Windows Error Message
The driver to download is the current driver installed for my printer. I keep getting a windows error when I try to print from programs...
  • Ziggy13 Mar 13, 2008
    The print test is fine, but when I go to print from the two programs I'm trying to use (MS Word 2000 and Corel Printhouse 3) I get Microsoft Word for Windows has encountered a problem or Corel Printhouse has encoutered a problem. Then I have the option of sending an error report. Thanks for the advice so far, I really appreciate it.
    Genius:
  • 3,587 Answers
Hmm..which windows are you using? sounds like a windows/applications issue...does the test print work ok?
Posted on Mar 13, 2008
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    hmmm...that's a little weird..what version windows you on? did you get the service pack updates lately?
I just got Windows 7 and just now installed Lexmark X125
Most likely the printer driver on the CD is not compatible with Windows 7. Download the latest printer driver from Lexmark. Click on this link to their WEB site :-
http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Jan 29, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
My printer keeps popping up with the error message "unable to print" - "check manual for troubleshooting" when I check the manual, it just says to turn off and leave off. Which we've tried, but it's still...
uninstall the printer driver , restart the computer , disconnect the printer and reconnect the same, the let windows pick the driver from windows update, if its not then download the latest driver from the web and install the same. fixed
Jan 11, 2010 | Ricoh Aficio SP-C210SF Printer
Error message 2753 MSI.dot4wrp message when trying to install HP Photosmart c4480
I had the same problem. I tried to install my new HP Photosmart 8550 printer onto my HP desktop, I am running on Vista 64 bit. Kept getting fatal error MSI.dot4wrp40 over and over again. Upset that my Windows installer was corrupted. I search the internet for this error and realized that this only comes up with NEW HP Printers and scanners. I went to Epson's website and downloaded a driver for one of their photo printers and downloaded the driver for the Epson Stylus Photo1400 Vista 64 bit driver, and guess what it installed I went and bought this printer and I am up and running again. Sorry HP I am jumping ship. The week before I tired to install this HP printer, I installed Print Shop Pro Publisher 23, Blackberry desktop, and Canon digital utilities which in fact all use Window Installer. All installed with no problem, and they are all working. I believe this error message has to be a conflict between HP and Microsoft's 64 bit OS only.... Google THIS ERROR and you will notice only HP comes up.
Dec 29, 2009 | HP Photosmart C4480 All-In-One InkJet...
When the HP C4385 printer driver is loading on my computer it stops and I get the following error message: C:Documen1admin~1local~1 empzs07casetuphpzshl.ice_suffix..exe There is more to the error code but...
This error message has something to do with the driver installation. Meaning that the installation cannot be completed because the driver could be corrupted.
If you get this error while trying to install the CD (driver) that came with the printer, try downloading and installing the driver from the Web site.
Please check the link below, type the code and click on download:
http://www.opendrivers.com/freedownload/282015/hp-photosmart-c4385-all-in-one-basic-driver-10.0.0-windows-2000-xp%28x32-x64%29-vista%28x32-x64%29-download.html
NOTE: Make sure that there's no current printer driver installed before installing a new driver.
Hope this driver works for you!
Nov 16, 2009 | HP PhotoSmart C4385 All-in-One Printer
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
I have Windows XP and want to use Canon Multipass F50 printer. I have downloaded the print drivers from the Canon website. My system is recognizing the Canon Inkjet BJ S630 . I was given instruction to...
Are you sure you downloaded the right drivers, and the one's needed for your OS? Please check the canon link here. I would try reinstalling them just because your system is seeing the wrong printer to begin with.
The error message in the print queue can be troubleshot by using the windows help & support print troubleshooter (available from control panel>printers & faxes> printing troubleshooter) or using the windows event viewer to see what error code is reported and tracing the cause of the error that way...
Frequently in such a case uninstalling the printer drivers and installing them again will correct the difficulty...also see this MS link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 13, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
HP PSC2355p all in one, cannot use scanner, error messages, cant
Try going to windows update, use administrator options, and download and install windows installer 3.1, and then try re-installing your printer.
Feb 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp psc1210xi all in one with gateway can't print!
install the drivers of your printer again. and change the usb wire if it is to old.thats it.
Apr 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
