Question about Refrigerators
Minimal cooling Not cooling. Is set on max setting of 7.
  • Anonymous Mar 21, 2008
    not cooling stays at 40 degrees in morning and in afternoon higher around 50 degrees?
Unplug the fridge for two hrs
maybe its not defrosting
plug it back in & see if it make any differance
Posted on Mar 14, 2008
SOURCE:
What exactly does max a/c and norm a/c do; the difference, and performance? What does recirc do and why is it available during max, norm, and bilev but not during defrost? The same a/c properties are...
Hello: Max cooling is when the recirculate door opens. With the recirculate door open, 80% of the air flow comes from inside of the car and 20% is outside air. That makes the cooling more efficient. Normal a/c operation is 100% of airflow comes from the outside. These settings have nothing to do with compressor operation. Also Decreasing or increasing the amount of cooling has nothing to do with compressor operation, what that does is control the amount of air going from the evaporator core either through or past the heater core. The a/c compressor runs the same amount of time regardless of settings on the control panel. Also in cool weather the compressor runs in the defrost mode to keep the windows from fogging up. None of these settings affect performance, the only time performance is affected is wide open throttle (WOT) in that mode the engine computer shuts off the compressor to allow max power of the engine, ie: passing gear.. When A/C is selected the compressor is on, none of the settings will affect gas mileage, ie, low/high, max/normal 60 degree or 90 degree.
Jul 22, 2011 | 1997 Buick LeSabre
Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Nov 03, 2009 | Refrigerators
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
My problem is when I turn on my air only kick in for a minute of cold air then it shuts down then warm air comes out for five minutes maybe less. my setting are at max cool thermostat at 7. at these...
if it is in the middle of winter that you are doing this it has still got a very slim chance of doing what you want... it is a thermostat afterall which is preset by the manufacturer, take the settings off automatic and turn onto cool only.... atleast that way you will not generate a heating signal
Jun 16, 2009 | Heating & Cooling
Battery setting
The optimal power settings for any user differs due to how the laptop is used. The home/office and always on settings can be used when AC power is attached to the computer since it is not drawing power from the battery. If you are frequently using the laptop on battery power, you should be using the portable/laptop or max battery settings to allow the computer to run longer on a single charge. You can also customize the settings for these power modes or create your own custom power mode to control how long the computer needs to be idle before it starts shifting devices into a reduced-power mode.
May 31, 2009 | Dell Computers & Internet
Temp control switch does not regulate temp i get heat on all settings except max ac
switch prolly not bad but you might wanna look into your heater control valve. valve not closing and letting the hot coolant fill your heat exchanger rather than recycling it back to the cooling system. The heat is over powering your a/c system and you're only getting a bit of cooling when you have the a/c on max. try it out
Jul 20, 2008 | 1996 Ford Explorer
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
