My wired SMC router's blinking linghts aren't turned off after the PC had been turned off;the DSL modem loose the signal more frequently.I didn't set the pass word for the router,please help me to set it up.
  • 73 Answers
Try firmeware update from makers site and latest drivers for it ok how old is it also if they get to old they just die anyways
Posted on Mar 13, 2008
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
D-Link DSL-504T driver disc missing, looking for Win 7 compatable driver for modem.
No driver needed since you aren't connecting the pc the the modem, but to the router.
Connect the pc to the D-Link DSL-504T with a LAN cable, access it from a browser by going to this IP - 192.168.0.1 - , in there access the modem settings and configure it accordingly.
Jun 20, 2011 | D-Link SWT DSL-504T ADSL MODEM with 4...
My wireless ADSL2+ Router is having a problem, The ADSL Blink is going off within a few minutes of Internet use, Could you suggest me a solution?
Please check the following
1) secure cable between modem and router. it must not be loose.
2) secure cable between modem and phone jack. it must not be loose.
3) modem and router must not be near to any electromagnetic devices such as halogen lamps, computer speakers
4) cables must not be intersecting to electrical cable which sometimes cause static signals that interrupts internet signals going to modem or router
Feb 15, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Motorola MSTATEA takes long time to "reconnect"
Check the speed and call ISP tech support to run the line test
Before calling them do a complete power cycle
Turn the modem off and the computer off and router if any
Wait for 30 seconds and turn the modem on and wait for the lights to turn solid
Once ready turn router if you have else computer
Delete the temporary internet files browsing cookies,cache memory.
If the modem turns too hot after running for an hour please replace the modem
DSL light blinking green indicates that there s no proper signal to the modem
Check the wall jack for any loose contacts
If you have any filter check them too
Isolate them and try with it
Change them if possible
Feb 06, 2010 | AT&T High Speed DSL Modem
Dsl modem network cable attached modem icon
Are you trying to set up the router ?
First make sure that your computer is online when connected directly to the mdoem. ISP is DSL.
If not online through the modem then you should have user name and password for the ISP.
try to reconfigure the router.
Click Here for more info about router set up.
Nov 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wrt54gx2 dropping out, loosing both wired and wireless signals
Try to upgrade the firmware of the router.Download firmware file from http://www.linksysbycisco.com/US/en/support for your model and open 192.168.1.1 Leave username blank and in password type admin click on administration and then on firmware upgrade.Browse and select the downloaded file and upgrade the firmware.
Apr 12, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Dropping internet connection
check if this problem is with both wired and wireless computers, if not with the wired..only wireless has problems, check if you have any other wireless device operating in the same frequency of the router..if s, turn off other devices and check b.cos that me interfere your w/ls connection, if wired is having the same problem, connect modem straight to the pc and observe the connection, so that you can isolate problem..
Nov 04, 2007 | SMC Barricade 7004 Router
For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
Jul 29, 2007 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
How do I power cycle the Modem and Router?
Power OFF the Cable/DSL Modem, then the Router and wait for couple of minutes. Now power ON the Cable/DSL Modem First, after the modem gets initialized, Power ON the router.
Feb 19, 2006 | SMC Barricade Turbo Router
Computers & Internet Logo
David Payne
David Payne
