Question about Tomtom ONE GPS Receiver
Unable to obtain GPS signal
My TOMTOM ONE has developed a fault in that it won't find a gps signal. I have tried a reboot by removing the SD card & inserting a paperclip for 15 secs, etc as per TOMTOMs instructions.
I have also tried the tip for resetting by pressing the bottom right side of the screen and switching the unit on.
In both cases the unit is still refusing to find a signal & I'm now lost as to what to try next.
Any help would be gratefully recieved.
Thanks in advance
Pete
  • drifter2008 Mar 13, 2008
    Same problem with Magellan 3200
    Genius:
  • 3,587 Answers
How to contact Support
Unable to obtain GPS signal - icon_register.gif Need information on how to use this site? Or how you can contact us? Follow the link below or call
Posted on Mar 16, 2008
My tom tom one has been trying to find a gps signal all day. It is asking am i i na building? it whas worked perfectly up to when i booted up this am!
Have you tried a hard reset? if not switch off the unit remove the sd card and stick i pin/clip into the small hole by the sd card slot for 15 seconds, then replace the sd card and power up.
Feb 12, 2010 | Tomtom ONE GPS Receiver
I was in Seattle when my TomTom froze up saying it could not find a GPS signal. I have driven on to Portland and it still indicates it is in Seattle and unable to find a GPS signal. I have tried...
it has just lost its satellite link, try resetting your unit by placing a small clip or pin into the hole next to the sd card slot, press and hold for around 15 seconds and restart your unit, it should then fin your position and allow you to carry on
Feb 07, 2010 | Tomtom ONE GPS Receiver
Tomtom can't get signal
Try to reset it, make sure it is switched off remove the sd card, get a pin or clip and place it in the small reset hole at the bottom of the devise for 15 seconds, then switch the unit back on and replace the sd card and hopefully it should come to life
Dec 31, 2009 | Tomtom ONE GPS Receiver
Unable to download map onto tomtom one xl
If you have an older tt xl it will only take up to a 2gb sd card. Larger than that you will get errors.
Hope this helps
May 30, 2009 | Tomtom ONE GPS Receiver
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Map on tomtom go 300
The downloaded maps can be copied direct to the SD card or copied to the SD card via USB lead and PC connected through TomTom Home. Once you have the map on your SD card you will need to activate it with your product code number that you obtained when you purchased the map.
Good luck
Sep 01, 2008 | Tomtom GO 300 GPS Receiver
Tom tom one
This problem can have several causes.
  1. A component fault on the units internal antenna circuit board.
  2. ribbon cable has become detatched inside that connects antenna board with main circuit board.
  3. A software fault.
  4. A component fault on the processor board.
All the above except number 3 will require proffessional investigation. if its a software fault then you may be able to recover data by a re-install through TomTom Home or by recovery backup ( you did make a backup of your SD card , didn't you ? ) of your SD card.
Aug 26, 2008 | Tomtom GO 700 GPS Receiver
How to install 1gig memory card into tomtom oneXL
I red cross usually indicates an SD card problem.
With most tomtom's usually removeing the SD card and powering up will resolve the issue.
If not then a HARD reset without the SD card may be called for.
If it does prove to be an SD card error then formatting in a proper card reader using FAT32 as the file system and then copying the files back over from the tomtom usually does the trick.
Or format and restore from a back up to the card. can work too.
It may also mean that a files might have been deleted or become corrupted.
Ppush the card into the gps and let go
it should come out a little to allow you to remove it.
(do that with the power off !)
power up the gps again and if it works the card is a minor fault that can usualyy be fixed by tou prettyy easily.
If it still does not come on properly then look for a tiny hole near the SD slot
get a paper clip and and with the gps switched on pust it into that hole keeping the paper clip straight (dont push too hard)
Hold it for about 3 seconds and release.
your gps should reset itself.
If it stays off try to power it up.
It should now power up but you may have to tell it all your personal settings again.
The tomtoms don't die too often compared to other makes
and even when they lock up they can usually be brought back to life
Jul 09, 2008 | Tomtom ONE GPS Receiver
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
