Question about Dell 942 All-In-One InkJet Printer
942 DELL PRINTER WILL NOT PRINT FROM PROGRAM
I WORK IN A PROGRAM THAT IS CALLED COMPOSER FOR SIGN APPLICATIONS. I CANNOT PRINT FROM THIS PROGRAM. I CAN FROM ILLUSTROR OR PHOTO SHOP OR EVEN MY EMAILS. I GET THE MESSAGE EACH TIME I TRY. "THE PREFERENCED PAPER PRINTER IS EITHER UNAVAILABLE OR ITS PREFERRED SETTINGS INVALID. I HAVE CHECKED AND RECHECKED THE SETTINGS AND CANNOT FIND THE PROBLEM. I HAVE REINSTALLED THE PROGRAM BOTH FOR THE PRINTER AND COMPOSER. ANY SUGGESTIONS THAT I MIGHT TRY WOULD BE GREATLY APPRECIATED.
Hey why are you using sonikay as a name
who are you and where did you find that name
Posted on May 10, 2008
  • sonikayn May 10, 2008
    please if you get this tell me why you are using sonikay as a name
    sonikaynsonikayn@hotmail.com
    Im curious i use that name, i made it up who are you and why are you using it?
    Genius:
  • 3,587 Answers
Did you check for compatibility with your composer and the dell printer?
Posted on Mar 13, 2008
Have a dell 942 AIO. graphics in grey seem to print purple
what OS are u using ?
U may will have to unistall the driver Again ( make sure that the printer is unplugged) . run Patch .. ( Available at support.dell.com )
Reinstall the Printer drivers again ( downloading from Dell Website .. install them ( make sure that the cable is connected only when Prompted ) )
This should resolve the Problem
Mar 20, 2010 | Dell 942 All-In-One InkJet Printer
I am trying to download the Owners Manual for Dell Printer 942
You may want to try these:
Dell 942 in pdf
Dell 942 in HTML
HTML needs to be downloaded and saved on your computer. Once you have it extracted, it will appear like a Help program.
Note: disable your Pop-up blocker temporarily if you can't open the link.
Nov 02, 2009 | Dell 942 All-In-One InkJet Printer
Dell all-in-one 942 printer
hi tnstiger00,
you can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just update me if you're still having issues with the printer.
Oct 14, 2009 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Prints in HTML code
Old MS article posted HERE and more recent info related to Program Access and Default Browser settings HERE.
Feb 01, 2009 | Dell 942 All-In-One InkJet Printer
Dell 942 printer
Here is the link for the drivers & application for AIO 942 printer:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A942&hidos=WW1&hidlang=en&TabIndex=
All you need to do is go to above link & download & run the upgrade/patch first. It will uninstall the drivers for the printer & thn download & install the drivers.....once the drivers are installd, you will get the aio center.....do let me knw if ny further help is required...
Jul 21, 2008 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Wont' Scan
try uninstalling & reinstalling the drivers....tht wld fix the issue...
Apr 16, 2008 | Dell 942 All-In-One InkJet Printer
Installing 942 onto inspiron 5100 - can print, can't scan
try to fully uninstall the driver, restart computer and printer. download and reinstall driver from support.dell.com drivers and downloads website.
Feb 13, 2008 | Dell 942 All-In-One InkJet Printer
I have had the clear carrier jam problem the past 3months, spoke to over ten technicians but no one seems to have been able to resolve it, let alone clearly explain the cause. But just to say buy another printer.
How many Dell 942 printer am I going to buy!!!!!?????
Sep 09, 2007 | Dell 942 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
