Question about Directed 1100d Car Audio Amplifier
Sounds problem i was driving with my m8 in and all of a sudden theres no sounds from my speakers. ive checked the amp and the power light doesnt light, ive already changed the fuses on the amp. the headunit shows the music playing but theres no sound. all my speakers are connected to the amp so no sound at all.
  • 3 more comments
  • sadfer Mar 13, 2008
    hmm sounds reasonable i havent checked the ground only the live ill check it soon as. The inline fuse is fine as well so ground it prolly is cheers.
  • sadfer Mar 14, 2008
    hey zzedly ur third point made the amp wrk but ive got another problem, when i turn my car on all my speakers and sub make a pop noise as though theres a surge of electricity, you got any ideas on that, it could be coz i used a paperclip to test it out but i dnt kno.
    erm well the power light stays on all the time, so i guess it does, but i read the manual and it says i shouldnt connect the rem with a constant 12V supply. So im gonna check the entire connection from the head unit to the amp as well. take any suggestions though
    yer i have thankz mate shud rank ur self up again hehe
  • sadfer Apr 10, 2008
    ive checked the head unit and i cant find anything wrong, all the wires are hooked up etc. i have a new problem now. when i hook the rem to the +v with a piece of wire the amp turns on but only goes in protection mode, and this is when the car is turned on otherwise its off.
    p.s. i hooked the rem to the +v to test if the amp still turns on.
    Sergeant:
  • 300 Answers
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Posted on Mar 13, 2008
  • 1 more comment
  • Tygh Duval
    Tygh Duval Mar 14, 2008
    Question: With the paperclip tying the remote and +12V connections together at the amp, does the amp stay on all the time? Or does it turn on only when the car is turned on?
  • Tygh Duval
    Ok, that makes sense. I think the root issue here is your remote wire is not giving your amp the "turn on" signal. Tying it to the +12V will cause the amp to stay on 24/7 and could also cause the amp to "pop" on turn-on. I would check the remote connection, from dash to amp, and make sure it's working right. In the meantime, remove the paperclip so the amp doesn't drain your battery :)
  • Tygh Duval
    Tygh Duval Apr 10, 2008
    Try removing the speaker wires from the amp and see if it still only turns on in Protect Mode. If it does, it sounds like the amp has internal problems. If it doesn't, try reconnecting the speaker wires until the amp turn on in protect mode. Then that wire will be the one to check, end to end, that it's not grounded, touching +12V, etc.
    If you have a meter handy, you could check the REM output from the head unit with reference to ground. You should have almost 0V when the head unit is off and (I believe) +12V when the head unit is on.
Ive had my speaker for a week and it stopped working suddenly. Ive had it plugged in to recharge but the light is not blinking yes Ive confirmed outlet is working etc.
A bit more information is needed but here is a couple of thing to try. If these are wireless then make sure the send/receive unit is properly seated. If these are amplified speakers (speaker has the amp built in) then check the fuse for them. If these are wired speakers then you need to check the connecters.
Feb 08, 2016 | Audio Players & Recorders
Ive been having issues on & off with my speakers that i installed back in april in my 95 GMC Sonoma. It seems that on some days i can listen to them at a pretty good volume. Then all of a sudden they'
Sounds like a bad ground. Try reattaching it first. Double check any splices also. And the source for the amp, if you tied on to speakers or spliced, double check it.
Aug 09, 2013 | Car Audio & Video
Speakers getting power but not sound
check the speaker.. could be burned or open connection
May 17, 2010 | Logitech Z523 2 Speakers
Speaker works only in one
No, i don't think so, but probably you audio was disconnected
Check the sound properties on control panel.
Check back connections, the power of your speakers. (bad power supply - replace)
Check your speakers on another computer
Oct 06, 2008 | Altec Lansing VS2321 Computer Speakers
Nitro BMW 1000w amp not working
if AMP turns on and no sound , check the inernal fuses that protect the output from overload , in most cases this fuses act like a cicuit breaker , they set back on again in a few seconds. hope this helps
Apr 28, 2008 | Nitro BMW-481 Car Audio Amplifier
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Apr 12, 2007 | Jensen LXA400 Car Audio Amplifier
Have no sound on front and rear speakers...
looking at the front of the unit take the left side pannel and replace the fuses. ive had to do that with mine several times because of the same problem
Sep 10, 2006 | Sharp CD-C460 Shelf System
My amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Apr 07, 2006 | AudioBahn A6004T Car Audio Amplifier
Directed 1100d Car Audio Amplifier Logo
232 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
