Question about Philips 17PF9946 17 in. HDTV-Ready LCD Television
Tv not working
I have a 17 in. When i turn it on itwon't come on right of way. I have turn it off and on a few time's before it works. Then when it starts working about a half hour later it starts the hole thing over again..
    Sergeant:
  • 395 Answers
Go to philips web sight and download the software update. you will need a usb flash card.
Posted on Mar 13, 2008
I got no image & the tv turn it offa few secondes
Do it work after some time? Is picture and sound are OK after that? Provide more details please.
May 29, 2012 | Philips Magnavox 20MT133S 20" TV
My hisense locked and I don't have the original remote
This worked like a charm for me. I used the buttons on the side of the TV, since I've lost the original remote. Good luck! I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
Oct 25, 2010 | Hisense TL1700 17 in. LCD Television
Why would the Gateway FPD 1730 17 in. Flat Panel LCD Monitor turn on,,then go right back off,,if you leave it unhooked for a few days then it will work for a short time than quit again
This sounds like a typical Capacitor in the Power Supply fault. Some people take them apart and replace the capacitors, however I recommend that you get a "Quote" for repair, as these often "Chain Fault" and I have seen a lot of disappointed would be fixers.
Feb 20, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
Magnavox 20MT4405/17 Error and remote control problem
what you describe sounds like you have a short inside the safe bet is take it to a repair shop.
Oct 05, 2009 | Philips Magnavox 20MS233S 20" TV
My Vizio turns itself off on a certain channel (ch 17-1 Phila)
I have this same problem with channel 5-1 Los Angeles anyone have any advice?
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Magnavox lcd tv 15mf050v/17
I put heat-sinks on U14 and the regulator above it and the TV has been running fine all day. Always shut off after 14-30 minutes before. Heatsinks were just 1/2" x 1" metal strips with silicon thermal compound that I taped up to hold in place to temporarily test, as it is obviously a heat related problem.
If you try it and it works for you, post it here.
mwl777us@verizon.net
Dec 11, 2007 | Philips Magnavox 42MF521D/37 Television
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Memorex MT 1701 Screen Problem
ok for those of you having the problem with the memorex mt1701 lcd tv / pc monitor well i had got one of a site call cl anyway when i first turn on it would stay on then turn off all i could here was the sound ok well i figuerd for sume reason the pc mode is the only way to get it to work right!! dont ask me y? but heres how to keep it on and able to watch tv. ok first when you turn the tv on it will go blank after a few when it does on your remote turn it to pc mode that will b the next one after tv you won be able to see if its in pc mode unless you turn the tv on and off a few time but you dont need to do that cuz pc mode is right after tv mode ok so your in pc mode you still wont see anything but what you want to watch for is the the power light it will remaine green for a few seconds than change orange when it does turn off tv than power on in pc mode you will see a no signal sign blinking swithch to the next mode quikly before the light goes orange again after this youll be able to watch tv but keep in mind iv had to youse this methode every once in awile. sumtimes whe id turn the tv of and on it would go to the blank screen again and sumtimes not so i hope i helped sum of you with this problem but thats the way this tv works for sum reason if you have any questions feel free to ask thanks and i hope this help you!!!!!!!!!
Feb 19, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Philips 17PF9946 17 in. HDTV-Ready LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
