Check for media jams in the paper exit area under the fuser cover.
SEE 8-13 for diagram of fuser cover location. http://www.xante.com/download/Legacy-Color-Products/Colour-ScreenWriter-Series/Colour-Laser-Series/ColourLaser/Manuals/Troubleshooting%20-%20English/cl_troublesh.pdf
Hopefully this is all it is other wise it may be more sinister like the fuser roller has fused together -
I have had this happen on another printer . Because I did not remove the power before I removed the fuser unit in a different model and make of printer. And fused the rollers together like melted together in the fuser. I think you would get an error code if this was the case !
Scan the document and save it.
Lift the lid on your scanner lay the photo face down then select scan
document/photo it will ask what format you want to scan it then it will ask
where you want to save it browse select the file/folder where you want to save
it (my pictures) most common
you can send an
attachment to a company by an email
Open up your new email type
in the adress then you should see attachment depending on which email you are
using select attachment then you will open up a browse window navigate to
your
document
/ attachment select it you might have to wait a few seconds for it to load as
an attachment then click send.
1. Select Tools from the top menu 2. Choose Internet Options 3. Click on the Security tab. 4. Click on Custom Level. 5. Scroll down until you see section labeled Scripting. 6. Under Active Scripting, select Enable. 7. Click OK to save changes. 8. Close and restart Internet Explorer.
Internet explorer 7:
1. Open your browser. 2. Click on Tools button (it is located in the upper right part of the screen) 3. Select Internet Options. 4. Click on Security tab. 5. Click on Custom Level. 6. Scroll down until you see section labeled Active Scripting. 7. Select Enable and click OK. 8. Click OK to save changes. 9. Confirm Yes and click OK. 10.Close and restart the browser.
Enable the Sun JRE though your Web browser:
1. Click "Tools" --> "Internet Options" 2. Select the Advanced Tab, and scroll down to "Java (Sun)" 3. Check the box next to the Java version 4. Next, select the Security Tab, and select the "Custom Level" button 5. Scroll down to "Scripting of Java applets" 6. Make sure the "Enable" radio button is checked. 7. Click OK to save your preference.
With most laser printers whenever I see this problem It means that you had a paper jam but did not get all of it out. something is impeding the straight flow of the vellum. Most likely there is a piece of vellum stuck somewhere inside that you cant find.
