Question about RCA P50830BL 50" Rear Projection Television
RCA P50830BL I have had this tv for about 8 years now. recently while watching the tv, the three colors would seperate so everything was red , blue, and green. I found that if I turned the set off and then right back on it would fix itself. Or if I went into the menu and used the alignment feature it would fix itself. Well to make a long story short....it went out the other day and i tried the turn it off and back on trick with no success. I went into the menu and the alignment feature isn't even there anymore. That is pretty much all I can tell you other than i had the high voltage transformer changed out a couple months ago. Can you help? Is there something I can do or do I have to call a tech?
  • stephaniegoa Apr 16, 2009
    I have the same problem that the option for alignment is not available but it happened after i replaced the main fuse. Everything works fine now that i have replaced the blown fuse but the alignment option is gone from the menu. I've tried unplugging it, removing and replacing the fuse in hopes that there will be some kind of reset. But no such luck has come as of yet.
  • 61 Answers
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Posted on Apr 01, 2008
SOURCE:
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a 32" sonya tv about 10 years old.... Have no red color any more.. Where can I get this fix and would it just be cheaper to go get a new tv.
tv producess three colours red, blue and green, each of this has a different input on the tube (crt)
each has a seperate path from the IC to the tube neck.
on the tube are three transistors, each one for one colour,these transistor can be tested individualy,
if all this does not work, then take your tv for rejuvanation (opening of gates on the tube in puts)
Apr 30, 2009 | Sanyo Televison & Video
Color Problem
prob bad crt. blue gun weak. new tv is answer.
Nov 17, 2008 | Zenith B25A74R 25" TV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
61 in RCA Rear-Project color seperation
Your used TV is not worth much. Let us not fill our land fills with TV's. You may give it to a charitable oranganization (tax deduction) or local school that has an electronic course. Enjoy your new LCD you a great choice in type and brand.
May 04, 2008 | RCA P52926 52" Rear Projection Television
Red Convergence won't adjust
iam having the exact same issue any idea on ow to fix this?
Nov 27, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
161 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
