Washing machine is smoking
My washing machine has been making some fun noises latly. and to day it started smoking and smelled like burning rubber so i turned it off an checked the belt but it wasnt the belt can you tell me if i need a new washine machine.
  • shazmonkey Mar 26, 2009
    My washer started to make a loud banging noise and after a while i noticed a burning smell. I quickly turned it off and unplugged it. on opening the drum door lots of smelly smoke kept billowing out.
huuum
  • 750 Answers
SOURCE: smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Posted on Oct 06, 2008
rickzilla
  • 706 Answers
SOURCE: smoke coming from back of
You may have overloaded the washer and the belt drive system could not handle that excess mass.. The smoke and burning smell is a belt melting while trying to rotate the drum.. I would unload it .. gain access to the drive mechanism ( probably via an access panel in the back but may not be.. - brand and model specific).. and then check for damage to the drive belt.. You may look at the pulley system and look for burnt black from melted belt on it.. You could also have a clog in your pump that the belt drives but can't ( because of that clog) and therefore the belt rubs over the pump pulley and melts.. Could be any one of those things.. Hope that helps..
Posted on Aug 24, 2008
  • 163 Answers
SOURCE: change belt.
this is a easy job for a tech but a hard one to regular people have to remove the transmition and thats is by removing a nut in the tub, so better call a tech and pay for it, is not to espensive repair at least in my area...good luck
Posted on Aug 07, 2006
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
smartr10U
  • 1305 Answers
SOURCE: Washer was pouring out smoke and smelled liked burnt rubber
You most likelyhave burned a drive belt. Could be a couple things. If the machine was loaded to the max and a bit more, it is possible that a small article of clothes may have been flung into the outer tub and into the pump... this can freeze it up and the motor will keep trying to turn the belt against a frozen pulley.
You'll need to open the machine and check the pump for blockage and change the belt... let us know if we can help with procedures..
k
Posted on Jun 25, 2009
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Smell of burning rubber and smoke from drawer
Sounds like your drive belt is loose or worn out. You will probably need a new belt. Is it possible something got inside the machine and jammed the belt?
Dec 12, 2014 | Hoover Washing Machines
Westwood T1600 Smoking and burning smell?
Burning rubber smell indicates that you must have a worn out belt that is starting to slip making the burnt rubber smell. I think you need to replace at least one belt, maybe more upon inspection of the rest.
Jun 21, 2014 | Garden
During spin cycle a grinding noise starts and a burning smell develops if I let it spin on then smoke comes out
could be your motor coupling, clutch or brake linings. if it smells like rubber burning then it is your motor coupling,, ,,,,mine was doing that and found out the clip that holds on the part to disengage the brake had ground off the end of my basket drive tube and the arm fell down thus no spin ,part cost more than the washer is worth! guess i'll be picking up a new 1! yea the grinding noise could be in your clutch,brake area!
Feb 10, 2010 | Kenmore Washing Machines
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
My model number is LAT 9593. The machine will fill, wash, but will not spin. I smell a slight electrical burning smell.
It sounds like your motor has failed. Let the washer sit unused for a day. then turn the washer to spin. Sometimes the motor will start cold. Replace motor.
Jul 01, 2009 | Maytag Washing Machines
Smoking burning rubber smell from machine
Welcome
Change belt
Let me know.
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
981 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
