Question about LaCie Rugged All-Terrain (301175) 160 GB FireWire 400 (1394a) Hard Drive
Lacie Rugged 160GB not being recognized in "My Computer" window
The computer recognizes the device and says it is working properly, all the usb ports are working properly, but I cannot select the device in the "My Computer" screen so I can't access it to save anything to it
  • 4 more comments
  • Anonymous Jun 26, 2008
    On a mac computer, usb cables all fine, cant find the LaCie rugged hard drive any more.
  • Anonymous Oct 03, 2008
    yeh its the same with me, its says it ready to be used but it doesnt show up in
    'my computer"
  • Anonymous Nov 11, 2008
    I have the same problem... it is as though the computer recognizes it as a usb mass storage device, yet does not actually create some way of accessing it
  • jennyb10 Dec 17, 2008
    I need to get something off a Lacie Rugged Drive but my computer won't recognise it. It is usually used with a MAC but I have a PC - would this make a difference? I've downloaded the latest drivers but it made no difference.
  • phnafum Jan 05, 2009
    Can't see the device in order to map it. Would prefer a solution that does not involve reformatting, as data is already stored on the drive.
  • ja m e May 14, 2009
    on a mac. 300gb hd version.
    this drive keeps on disappearing. sometimes recognized sometimes not. will always disappear after a certain amount of time.
    this is my second failed lacie rugged in one week. first one had the same symptoms and then terminally failed.
    am simply waiting for this one to die completely before i take it back. if I return it in this half dead state then the retailer tells me theres a good chance lacie will simply send it back after 3 weeks.
    do not trust this hard drive.
    certainly do not buy it.
    check google for evidence.
    Genius:
  • 3,587 Answers
You may need to add that drive, under the my computer panel
Posted on Mar 13, 2008
I went into 'my computer' to 'view system information' then 'hardware' then 'device manager' then 'USB controllers' if necessary, and saw a red x through one of the usb symbols. i clicked on it, and it listed my rugged 250, said it was disabled, i clicked to enable it, and the computer found it, seems to be letting me backup now
Posted on Apr 19, 2009
SOURCE:
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
It spins but is not recognized by computers
What type of hard drive ?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps
b>
Dec 20, 2012 | Computers & Internet
Not recognice by usb hard
Hope this helps
Nov 07, 2012 | Computers & Internet
Unable to get message from computer to printer. Message always appears : "Does not recognize USB port " I have tried all ports. Printer works as I tested on another computer.
Go to BIOS .For BIOS please press del or F2 button on your computer POST .After enter in the BIOS select on board devices or Integrated devices.select USB option and select AUTO option in Legacy USB devices if more than one USB Port then enable all USB port in BIOS.After that if printer not working then pls re-install the printer driver again.
Nov 16, 2009 | Compaq Presario S6000NX (DQ178A#ABA) PC...
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
USB device not recognized
SOLUTIONS:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If the above two doesnt work, then try the following,
Disable power management of the USB hub. To disable the power management,
1.Click Start, and then click Run
2.Type devmgmt.msc in the Open box, and then click OK.
3.Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
4.Right-click the USB Root Hub and then click Properties.
5. Click the Power Management tab.
6. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
PS: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Jun 03, 2009 | Samsung CLP-315W Laser Color Printer
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
Hard drive not being recognized
dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Mar 17, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Usb ports
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Open Questions:
See all LaCie Rugged All-Terrain (301175) 160 GB FireWire Questions
LaCie Rugged All-Terrain (301175) 160 GB FireWire 400 (1394a) Hard Drive Logo
4,279 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
