Question about Splendide 2000S Vented Washer/Dryer
Washer doesn't agitate
Washer, fills, drains, fills, drains & does final spin. It does not agitate during wash, rinse, or dry cycle???
PLEASE HELP
  • 4 more comments
  • JDStoner Mar 13, 2008
    What do I do now??
    my husband is wanting to do the work himself, if possible???
  • docloc1 Jan 21, 2009
    The washer doe not agitate in either the wash cycle or rince cycle. Only the spin cycle works as it should.
  • Anonymous Mar 15, 2014
    will not wash agitator does not work
    will not wash
  • Anonymous Mar 19, 2014
    Centenial Commercial
"I'm not familiar with Splendide. who makes
that?"
Posted on Apr 07, 2009
    Genius:
  • 3,587 Answers
Sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    you doing the work yourself or call someone?
  • Patrick Michaels
    then he'll need a service manual, and some spare parts...I'm not familiar with Splendide. who makes that?
2 Suggested Answers
SOURCE:
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Splendide 2000S Vented Washer/Dryer Logo
655 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
Lawrence Oravetz
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
