Question about Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
We have Mitsubishi 40" television, model # CS-40503, which has performed flawlessly since we bought it. Just recently, the picture has occasionally shrunk to approximately a 4" horizontal picture accross the middle of the screen. The sound and color remain great, just everything gets compressed. This condition may last a few days then miraculously disappear. But just when you think everything is OK the screen may majically shrink before your eyes. Is my television ready to give up the ghost or does the diagnosis indicate a minor repair will provide us with some additional viewing pleasure.
  • gwinnett Mar 18, 2008
    There were in fact bad solder connections on the vertical deflerctor IC, Unfortunately, there were also two capacitors on the same item needing replacement. Since one of them had to be ordered, I cannot at this time say the problem has been solved. But hopefully the end result will be a couple of mor eyears of great service for about a $230 repair charge. Thanks!
    Sergeant:
  • 395 Answers
There are bad solder connections on the vertical deflection IC resolder them and you will be fine
Posted on Mar 13, 2008
The television is digital.
Posted on Jan 31, 2009
  • Anonymous Jan 31, 2009
    the tv is digital
SOURCE:
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
Mitsi CS-40503 turns on then off after viewing a while
loose connections on the power board,electrolitic capacitors is leacking.
Jul 02, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
May 18, 2009 | Mitsubishi CS-40503 TV
Just bought a mitsubishi 40503 dont have manual cant get my cable hooked up
check if the plug if your cable is fit for the antenna in of your tv.if ok then hook it up and do the manual/auto search of channels.
Mar 28, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
TV shuts off while watching.
if its worth fixing?compare the cost for repairs and a new one.
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
352 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
