Hey Anon..
WOA...compressed propane is not something to mess around with..I would go back to the Home Depot and talk to the store manager,,(take your receipt and all other paper work for proof), ask him who to see about your issue.. tell him you are afraid to use your NEW grill.(Start at the top!).. you spent good $$$$ and you deserve an answer..or a new grill..
its burning at same level after increased or its going low than high than low etc? Is there another appliances that uses same gas source with the grill?
Check the nozzles for dirt and bending or obstruction.
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
Turn off the gas at the propane tank
Disconnect the gas line from the tank
Open the grill lid
Turn all control valves to high
Wait for about a minute
Turn all control valves to off
Reconnect the gas line to the tank
SLOWLY turn on the gas at the tank
Light the grill normally
Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly.
If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
Open the grill lid
HI thanks for your question. the problem with your gas oven, is the igniter is not hot enough to ignite the gas. a common problem with gas ovens. replace the igniters. thanks the appliance doc. please rate my answer, if happy thanks-
