System Error: Code E000 Product manual: Turn off for 10 minutes. "if you cannot solve the problem" "call your service representative" I don't have a service rep. Please help. David717
    Genius:
  • 3,587 Answers
I posted a note with a contact number..this appears to be a service level request
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products System error - inactive_ln.gif800-828-4040us.gifinactive_r.gif
Posted on Mar 13, 2008
Error Code: E100 0000
Turn off the printer,wait 10 minutes,than turn it on. If not good yet,open the top of the printer.Look for small shooter that holds the laser.Open,and force the laser out into the center of tracking craddle.After you move the laser,unplug the printer for few minutes.Then plug it back in.
Feb 25, 2015 | Canon LASER SHOT LBP-2900 Printer
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
This is a print head error. If you have a cleaning option on the printer menu, please try that. If you dont, then you can remove the in cartridge and try cleaning the head with 1-tips and water or alcohol.
Jan 19, 2014 | Canon LASER SHOT LBP-2900 Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Solution 1:
  • Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
  • Flip open the top of the printer.
  • Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
  • After you move the laser, unplug the printer for a few minutes.
  • Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative
+1-855-517-2433(Toll Free)
Nov 25, 2013 | Canon LASER SHOT LBP-2900 Printer
Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service...
Fixing temperature control startup error
Temperature of the Fixing Assembly did not reach the specified temperature within the specified period of time.
Remedy1. Check connectors on the fixing film unit. 2. Replace the fixing film unit. 3. Replace the engine controller PCB.
for more help visit CBR Tech Solutions
Dec 03, 2011 | Xerox Phaser Office Equipment & Supplies
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
Apr 16, 2011 | Canon LASER SHOT LBP-2900 Printer
CANON IR1210 SERIAL NO OMA33665 IS COMPLAINING ABOUT SYSTEM ERROR E*** AND I HAVE TRIED THE SUGGESTED SOLUTION IN THE MANUAL OF THIS PRODUCT
Thanks for the info. on your copier. I looked it up on the web to solve your E*** problem. Oddly, I could not find the error code E***. Because there is not a error code in the service manual. To Help you solve your problem. Can you let us know the numbers that come after the "E"
Sep 16, 2010 | Canon Office Equipment & Supplies
System error E000
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
Feb 22, 2010 | Canon ImageRUNNER 1670F Copier
Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Aug 03, 2009 | Canon Office Equipment & Supplies
System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Apr 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
