Question about Tricity Bendix WDR1240W Front Load Washer / Dryer
Dryer Can anyone help please? We have a Tricity Bendix WDR 1240 W washer/dryer. When drying there is heat but the clothes are still soaked through even with small amount in the drum - I would even say they were wetter than when they have been spun. I have checked the drainage etc and all is fine and i have also checked the small belt inside the lid at the top of the machine which has previously slackened and this is fine too. Also checked the filter and seems to be filled with water that i dont think should be there (couple of breakfast bowls full) Any help would be great. Thanks Andy
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Posted on Jan 27, 2009
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Jan 14, 2014 | Tricity Bendix TM310W Electric Dryer
The dryer is spinning and heating but clothes wont dry
Check your dryer vent for any obstructions.All the moisture from the clothes is vented outside through this vent.
Jan 09, 2014 | Tricity Bendix TM321W Electric Dryer
Tricity bendix wdr 1241 emergency drain hose leak
Pull the machine out, if the back is removable, take it off. the connection should be close enough to reconnect...next time? don't pull so hard. if this doesn't work, take it to a reputable Repair Shop/Dealer
Oct 15, 2012 | Tricity Bendix WDR1240W Front Load Washer...
I have lost my manual need a replacement
Hi.
Please click on the link below to open the manual in PDF format.
WDR 1040 W WDR 1240 W
Regards.
Ginko
Aug 31, 2011 | Tricity Bendix WDR1240W Front Load Washer...
I have a wdr1242 washer dryer the dryer seems to take forever to dry clothes sometimes 2 hours or more even for just half a dozen socks
If your dryer is still heating up; Check the dryer vent hose, also check down inside where the lint screen goes. If no lint is obstructing there, check the exterior dryer vent. Sometimes you have a screen to keep birds and rodents out of there, and may become clogged with lint. If no screen, check inside the flap, maybe someone moved in, or dryer lint is clogging up your exterior vent.
Dec 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Hello! I've been facing problems with my washing machine. It seems that is working normally, but it's not drying any more. Even though the machine didn't stop working. I believe that something is clogging...
is the door glass hot when on dryer . can you hear the blower fan moving . if not get some one to remove top and see if blower fan is free (small black belt )turn appliance off at wall before removing top .if you still need help post again
Feb 11, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix WDR1240W Front Load Washer / Dryer Logo
277 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
