Question about HP Pavilion A520n (DW233A#ABA) PC Desktop
Power Outage - PC will not Boot up
We just had a power outage and when the power was restored my computer will not turn on. I press the on button and nothing happens. There is a green light in the back that is blinking. Is there a reset button? Please help.
Thanks,
Tim
  • tkmmc Mar 13, 2008
    I do have UPS. Would that narrow the cause?
    Genius:
  • 3,587 Answers
Nope...you might have lost any combination of these items:
A. Power supply
B. Motherboard
C. uProcessor
D. Memory
This is a good reason why folks use UPS devices. Hope this turns out for you.
Posted on Mar 13, 2008
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    well..if that was connected to computer, and now the computer is kaputsky, I'd say that the UPS was off duty at a critical moment.. try it plugged into wall, without UPS
Laptop wont boot up
Sounds crazy but try removing the battery unplug from power hold power button for 15 seconds Then plug in and try to turn it on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Mar 17, 2014 | ASUS U52F-BBL9 Laptop
Had a power outage and now my TV is not showing any pictures except for the blue screenn
Outage may have changed the input channel on TV so make sure you're on the right one. Press and hold the Power button on cable box. Let that restart. Unplug the router for 10 seconds and let it boot up.
Feb 07, 2014 | AT&T UVerse
Power light flashes but PC will not boot up following power outage
First off: Protection is important and the ONLY way to go is with a UPS (Battery backup protector). These devices allow the computer to SLOWLEY close down and protect the motherboard and hard drives. Simple bar protectors are of little to no use whatsoever. As for the Start UP; the Boot Sector on the Hard Drive has been compromised. If you attempted to start with the F8 key when you started up the computer and failed to Boot in the Safe Mode, you definitely lost the operating system.
You can try to do a Restore, but that may not be effective.
When a Computer starts, there is usually a Beep (called a Post) and one Beep indicates the motherboard is active. Several beeps indicate a mal-function of the motherboard and it was damaged. In some cases, the Memory (RAM) can be damaged from electrical surge, and thus the computer will not start and the monitor will not be active. Do not touch the internal leads as they are not the problem. In closing, a CPU is very sensitive to power surge and the CPU in some cases can be defective. All in all, with so may options or repair issues; only a professional has the equipment to search for the solution. Good luck: DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Evesham Axis 64 3000+ (AXIS643000+MAR04)...
Crashed after power outage, Using windows recovery disk, and now it's stuck at welcome screen
At boot up press F8 and from the B&W menu select Last Good Boot up or words to that effects. This will restore your laptop to the last good boot up date.
Else from the B&W menu select the Safe Mode.
Feb 10, 2011 | Sony VAIO VGN-FW230J/B Notebook
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
After a power outage computer will not turn on
first of all what kind of computer is i mean brand? secondly sounds like the power supply went bad..
Jun 12, 2010 | Computers & Internet
Computer will not boot up after power outage while running update
OK well if you can boot into Safe Mode, press F8 at bootup, then do so, and try a System Restore, back to a time before you had a problem Otherwise you will have to re-install your Operating System.
Feb 09, 2010 | Compaq Presario 2538CL Notebook
After a power outage, tried to power computer. All I got was flashing keyboard and power light while I held in the power button. As soon as I let go, everything goes dard. No start up sounds or anything....
Sounds like it could be the power supply was damaged from the power outage. If you have another PC you could pull the ATX power supply out and install it in the gateway and see if it boots up. Power supplies are fairly inexpensive so look for an aftermarket one...buying a replacement from Gateway will cost alot more. If the power supply turns out to be good then remove one device at a time the try to boot up. Sometimes a bad cd-rom drive or harddrive can cause a problem. My best guess it is the power supply.
Sep 10, 2009 | Gateway 560GE PC Desktop
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Power outage problems
Power outages can cause problems. Based upon the symptoms your motherboard or hard drive has been damaged.
Mar 06, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Pavilion A520n (DW233A#ABA) PC Desktop Logo
186 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
