Question about LG 42LC2D 42 in. LCD HDTV
Cnannel scan detects no channels
I have recently purchased an LG 42LB5D. During initial setup, auto channel scan cannot detect the channel 3 my Dish Network runs through. I know it's not the actual connection, because I had a similar TV hooked up the same way and it worked fine. Could it be that the tuner is faulty? Please help!
  • 3 more comments
  • anil35091 Jan 05, 2009
    no channels found
  • Anonymous Mar 13, 2014
    it asking us to please run channel auto scan and it wont get out of setup mode
  • Anonymous Mar 18, 2014
    auto tuner will not find channels
  • Anonymous Mar 31, 2014
    the tvis stuck on please run channel auto scan
    dont detect channel
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
Why am I getting the message "Please scan channels" on my TV. How can this problem be fixed please?
tv may have detected new channels or radio authority may have changed the channel frequencies. go into the tv setup and auto scan dtv channels.
A make and model number may yield a more accurate answer than this .
Sep 24, 2015 | Televison & Video
I am having trouble with the initial setup of channels, I can't seem to lock in the HD channels when going thru the beginning setup
The normal method is to do a full auto scan and once it's at 100% store or save the scanned list?if you try to do it manually you will take ages because some channels the polarity switches and parameters for the horizontal and vertical parts of the dish change frequency.
so make sure the cable is connected properly into tv or smart box and rescan.once it's reached 100% look for the save or store button on screen.the hd channels should be automatically put within the saved list and usually colour coded in the menu.when selecting channels.
Apr 02, 2015 | Initial Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
How do you do a channel search on a 32LC50C ?
Press the Menu button and go to SETUP. There is a quick scan selection that will detect both analog and digital signals. Or if you are using a optional receiver (digital), it will lock into the channel, most likely channel 3, to display the signal. I hope this helps.
Jun 21, 2010 | LG 32LC50C 32 in. LCD TV
I cancelled my dish hooked up a anttena but no signal
Go to main menu and select settings, initial setup, TV signal input, select Antenna, go to channel scan, select digital channel scan if there is a choice, or else channel scan. Wait for the scan to complete, 3 minutes or so. Exit menu, go to input and select ANT.
Wah Lah!
Jul 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Channels available in lnb 5150
Which sattelite?
Which band?
Which country?
Nov 19, 2008 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
658 people viewed this question
