Question about ASUS P5RD1-VM Motherboard
Hi melnavz, by the way thanks.as i said before,i press already f1 at the start ,set the time & date before saving(f10) ..everything is set..if i going to restart it..setting stood still..but if you turn-off..the settings is gone.. one thing more .if turn the computer on everytime the errors occurs.i need to press f1 for setting of time & date...f10 for saving..i believe theres something wrong with my unit... can you give me some any possible advices? more power to you hamlet
    Genius:
  • 1,226 Answers
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Posted on Mar 14, 2008
Dell Dimension 8400, I changed battery, now it shows Press F1 or F2 on start-up. If I press F1 the computer boots up, but how do I get back to a normal start-up?
Hello there and welcome to fixya
First off you need to be in bios then change the dateand time correctly in order for it to continue then oncethe date and time has been changed then press the f10 to save THIS IS WHERE PEOPLE MAKE MOST OF THIS MISTAKE THEY DONT SAVE IT TO BIOS BY PRESSING THE F10 KEY THIS WILL SAVE IT TO BIOS AND IT SHOULD RESTART THE COMPUTER ON ITS OWN
AND EVERY THINGS SHOULD START AS NORMAL
Mar 24, 2013 | Dell Dimension 8400 PC Desktop
F1 Ignore
So go into F10 and run the setup. It probably needs you to set the Date and Time correctly. Do that then save it and see where it takes you from there.
May 04, 2012 | Compaq Computers & Internet
I have a compaq m2105us and when i start it all i get is two beeps and a resume f1 and start f2
try to press f1 and resume set-up ..and make the changes for teh date and time ..and save all settings with F10 and restart ..it should work ..and load windows if it has one ..The fact that it let you go in bios is good news..it means it is not damaged but if it asks all he time f 1 to resume ..it means the hard disk may have bads on it in system check ..and this is causing the f1 call ... basically the systems tells you that you have a bad hard disk and invites you to change it ..or to press f 1 to go with it anyway ..
so..either is calling you to go to bios and set it ..cause you somehow reset the bios to the factory ..or it is a hard disk notice ..
I f it seam not to find any hard disk in teh system ..try to go to bios by pressing F2 or F10 cause it is a hp after all ..and in there change the settings for the ahci function and let it run ide compatible ..it may be the cause too for not booting up from hard disk ..
In the end I suggest to change bios battery ..cause a flat battery wioll also cause F1 on each boot to confirm the settings and set the date and time ..or just reinstall it cause it may have something on hard disk and caused the lost of data ..
let me know more about this if you can not manage or non of my scenarios does fit to the problem ..
Dec 23, 2011 | HP Presario m2105us Notebook
HAVE A PACKARD BELL LAPTOP EASYNOTE F 5275 IT HAS CMOS PROBLEM IT CANNOT BOOT WITHOUT SETTING CLOCK AND DATE AND THERE IS NO ANYWHERE IN MOTHERBOARD I CAN SEE THE CMOS PLACE KIND ASSIST
try to boot and when it asks to set the time and date ..press F1 to go to the BIOS settings and in there save like it is with F10..and enter ..will start anyway and you will set the time in windows..
or ...go to bios directly by pressing F10 if it is a HP computer or ..F2 for any other laptop ..and in there on the time settings just set the time and the date from the arrows and enter ..
if you have other problems and you opened it ...you will have to remove the Bios battery to default it to the factory settings ..this will eliminate any passwords that might had kept you out of bios...if you do not see the battery ..remove the wireless card and see if it is under it ..
Oct 02, 2010 | Computers & Internet
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
hi mayfield,
1)the problem is that cmos cell is not getting fixed or it is not touching the silverportion
2) just go to bios change date & time & save it will work
3) last option just remove all cable(hdd,cdrom,floppy,graphic card)& insert again than see it will work
4) if not than go the nearest shop & show him
Regards
shailesh
Mar 11, 2008 | ASUS P5RD1-VM Motherboard
Faulty time???
Hello!
That's the first time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
may this help!
Mar 03, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
