Question about i-mate JAM Pocket PC
Hi,windows mobile,i mate,now i can not open align screen, so what can i do?solve this problem
  • 32 Answers
Tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started with default configuration.
Posted on Dec 06, 2010
SOURCE:
Touch screen out of order
you should reset your mobile phone.if any touch screen is not functioning you can reset your phone.A pin hole is given near the usb port of phone for reset it.you can enter a needle into pinhole & press it slowly.after that your phone will reset.it take some moment. after it screen appers with text "align screen".taping the target until the "align screen" disappears.after disappearing align screen set which is given on the screen.after that windows will be installing.it take some moment.i hope your problem will be solved.
Dec 02, 2010 | i-mate JAM Pocket PC
Hi, I am not able to set screen alignment of my PDAL i-mate mobile
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Nov 08, 2010 | i-mate PDAL Pocket PC
Imate phone screen alignment
Hi
I am using i-mate Ultimate 6150.I made all settings as a Factory setting and my phone got restarted.Now its asking screen align.I am aligning screen more than 30min but still showing same .
Please give me instruction to solve problem
Thank you.
Jinkr
May 25, 2010 | i-mate Ultimate 6150 Cell Phone
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
I-mate jasjar does not align by tapping on different positions
1st thing to do is that, if you know how to disassemble your jasjar try to align the four connections behind the LCD or try to resolder it. If still not working, 2nd thing to do is you must change your Touch screen sensor. If you know how to change the sensor it's much better but if not, then you have to go to a mobile technician. Hope I help you with my idea on your problem there....
Jul 03, 2008 | i-mate JASJAR Smartphone
I-mate jam mobile align screen message appearing & stuck on that screen only. Plz suggest me sonlution.
me also, i-mate jama mobile, align message appearing and stuck on the scereen only.., wat will be the solution for this?//
Jun 12, 2008 | i-mate JAM Pocket PC
I-mate pdal touch screen promblem
press the POWER+CAMARA(SHUTTER)+CALL(GREEN) for 15 seconds after thuning the mobile on for the hard reset !!
if any problems then contact me via +919995153439(KERALA)
Nov 13, 2007 | i-mate PDAL Pocket PC
I-mate jam screen problem
Hi this problem can occure once in a whaile. you should do the "Align Screen" process. tap "start", then "settings", then on the Screen icon and in the generasl tab get to the Align Screen you will have to hit the target on the screen until the screen will be align again. hope this helped. Dagan
Jul 30, 2007 | i-mate JAM Pocket PC
i-mate JAM Pocket PC Logo
121 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
