Question about Gateway 507GR PC Desktop
Keeps cycling to BIOS screen...
I have a Gateway 507GR PC Desktop problem. =(
Not sure what happened, I didn't do anything risky. I pressed the power button on the tower and the BIOS screen comes up asking if I want to start in safe mode, last good configuration, or normal. I tried all of these and it just cycles back through to that screen. Any idea how to fix this?
THANKS!
  • el hadi Mar 13, 2008
    sound
  • pinkie890 Mar 13, 2008
    Thanks so much, Ben! I will try and see if it works!
    Scholar:
  • 64 Answers
Hi pinkie890,
It sounds like there is a corrupt file (or files) somewhere in your Windows installation. I'm guessing that you might see a blue screen with white letters and numbers flash up briefly before it cycles back to the boot options for Windows.
It's actually bypassing the BIOS screen if you're seeing the Windows boot options, so chances are it's either a) a problem with Windows or b) a hard drive problem (physically).
My first suggestion, if you can't boot into Safe Mode, is that you boot off your Windows CD and do a Repair. When prompted, DO NOT format the drive in either NTFS or FAT32 (you should have an option that says 'Leave file system intact (no changes)'. This will install a copy of Windows over your existing installation but won't wipe out your personal data files. There is always a chance you'll lose your My Documents but that's slim. Hopefully you have a good backup done recently.
This isn't the optimal way to go, but it should take care of the issue. I would recommend doing what I've suggested, backing up your data, and then doing a fresh installation of Windows.
Let me know if I can be of further help. If you have access to another computer with a CD burner, download the free Ultimate Boot CD. Pop the case off your computer and check the hard drive to see what brand it is. At that point you can boot from the Ultimate Boot CD, run Hard Disk Tools, and then run the appropriate hard drive diagnostics tools for your particular hard drive brand. If the advanced/long test comes back with no error messages, you can rule out physical hard drive issues and be more or less certain that the problem you're experiencing has to do with your software.
Ben
Posted on Mar 13, 2008
Power problems
JAKE, CHECK ALL ELECTRICAL WIRES,AND RE-WIRE ALL.
Aug 29, 2013 | Gateway 507GR PC Desktop
Don't have original disc to download instructions for a Gateway 507GR computer.
Gateway Support > Gateway 507GR Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/4658/4658nv.shtml
A) Click on Product Views
Click on the underlined blue subheading - Rear View
Where C points to is the I/O area. Input/Output area.
B) Click on Specifications in the Product View list.
C) Click on User Guides in the Product View list.
You can see the two posters listed for a quick setup.
Click on each one, one at a time.
These are PDF files. The next file is also.
Gateway Computer User Guide
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 14, 2012 | Gateway 507GR PC Desktop
Press on button w/in 10 seconds goes to sleep mode.... Gateway 507gr.
Go into the BIOS, POWER and change the setting to what you want, generally power off not sleep
Aug 06, 2010 | Gateway 507GR PC Desktop
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
How many electricity does 507gr uses?
It comes with a 300 watt power supply. How much it uses depends on all the devices it is running. At idle it may only use 150 watts or less, maybe more....depends on the load placed on it.
Jan 13, 2010 | Gateway 507GR PC Desktop
Gateway 507GR Wont Power-On after a power surge.  Had slight hissing noise in the Bestec power supply, replaced it, and it still will not always power-on. If I switch the a/c power on/off really fast...
Sounds to me the like soft on/off power switching in power supply itself is not working. Try another supply or if u have a tester try that. Wont be the motherboard or nothing at all would be happening.
Hope this helps
Nov 01, 2009 | Gateway 507GR PC Desktop
My Gateway 507GR PC desktop will not connect to internet
Turn off (unplug if necessary) your modem, router, and PC. Then power on the modem, wait a minute and then power on the router, then power on your PC, this should solve your issue if you have service.
Sep 08, 2009 | Gateway 507GR PC Desktop
My monitor wont come on it says it has no signal i turn onpc but monitor is blank
First open cpu cabinet then REFIX RAM memory.
Pull cmos cell for 10 minutes then all settings are defaults.
Then reconnect vga cable from your monitor to cpu vga port.
Then when you power up press continue F8 key so you can see safe mode and other menu then enter in enable vga mode then go to control panel then dispaly property then settings then change screen resolution to 1024*768 then apply and ok.
Then restart and check .
Aug 18, 2009 | Gateway 507GR PC Desktop
Does the 507GR support Wireless internet?
It is possible if u buy yourself pci wireless card. and connect it do your computer the second possible way is usb wirless adapter.
If helped rate fixya
May 03, 2009 | Gateway 507GR PC Desktop
Monitor keeps hibernating, can't make it stop, pixel issue.
Hey,
I think this is more of a problem on your computer instead of the monitor, ofcourse you could try another monitor and see if the same happens. I suspect your computer goes into standby or hibernation on its own, and it does work fine if you reset the computer right?
if you go into power management again, disable or turn off hibernation completely, its on one of the pages.
Make sure its not set to standby, and also disable your screen saver.
Right click on desktop - properties - then screensaver. turn it to none.
Also you could look into the computer bios and make sure its not set to standby or hibernation from there. thats unlikely but you could check.
how to get into bios.. depends on the computer, right when you turn it on, on one of the corners of the screen you will get a message, press button to enter setup or bios. press that to enter bios when its presented.
look around the bios and poweroptions.
Let me know if you need anything else.
Thanks,
Ekse
Feb 25, 2009 | Dell Dimension 8400 PC Desktop
Gateway 507GR PC Desktop Logo
204 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
